Thread: Car was way faster before the gears were programed
Results 1 to 11 of 11
  1. #1 Car was way faster before the gears were programed
    Acworth, Georgia
    Ok, So when I first got my 3.29s installed I drove my car back from the garage and befor the gears were programmed into the PCM it was so much faster. Wayy more power according to the butt dyno. This was the only time I drove it like that because I knew it wasnt too good for it. When I programmed the gears in tho it felt alot slower. This has always kinda been a question in my head. Any insight would be appreciated. I hope im not sounding dumb im just curious.
  2. #2 Re: Car was way faster before the gears were programed
    2.93's have a higher shift point in normal driving than 3.29's. Dependin on how you programmed them, they can be changed as long as you aren't over revving.
  3. #3 Re: Car was way faster before the gears were programed
    Acworth, Georgia
    Well it would have been 3.69s right being a gtp. And the car seemed to shift when it was supposed to just fine. It was shifting really hard if I remember but that was it. Just wondering if I messed up programming my gears or not. I put 3.69 in the ratio block after getting my 3.29s because thats what I read to do. Am I wrong?
  4. #4 Re: Car was way faster before the gears were programed
    gtp's have 2.93's. Gt's, se's and comp g's have 3.29's
  5. #5 Re: Car was way faster before the gears were programed
    Yeah...factory GTP gearing are 2.93's.
    No 3800 car came from the factory with 3.69's.
  6. #6 Re: Car was way faster before the gears were programed
    Acworth, Georgia
    Ohh yea, been awhile since I had to mess with gears. So am I right with how I programmed it?
  7. #7 Re: Car was way faster before the gears were programed
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    Blue Forgets the GSX Regals?
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  8. #8 Re: Car was way faster before the gears were programed
    Quote Originally Posted by 1LoudGrandPrix View Post
    Were nothing transmission related...those were engine mod cars...PCM, intake, exhaust, pulley...
  9. #9 Re: Car was way faster before the gears were programed
    Acworth, Georgia
    But in hptuners when I had 2.93s it said I had 3.29s. Then when I got my 3.29s I put 3.69. Is that right???
  10. #10 Re: Car was way faster before the gears were programed
    Portland Oregon
    No that is incorrect. The differential final drive ratio is always 3.29. It's the sprocket size that causes it to be 2.93, 3.29, or 3.69. Go back in, put in 3.29 back in that field in hptuners and on that same page there should be Sprocket Ratio that will be at something like 1.12xxx. You need to change that to 1 and then program for your correct shift points if you haven't already done so.
  11. #11 Re: Car was way faster before the gears were programed
    Acworth, Georgia
    thanks man. Thats probley why my cars been so slow.
  1. Faster car
    By slopez in forum General Tech Discussion
    Last Post: 01-24-2011, 02:03 AM
  2. make my car faster
    By monkyman18 in forum General Tech Discussion
    Last Post: 09-06-2010, 11:52 AM
  3. want to go faster
    By monsterjam5000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2010, 06:55 PM
