Thread: Fixed broken valve spring, Still misfiring heads are off
Results 1 to 17 of 17
  1. #1 Fixed broken valve spring, Still misfiring heads are off
    Acworth, Georgia
    Like the title says. I changed my broken valve spring that i thought was the problem but Im sill getting a misfire from the same no 5 cylinder. The car sounds a little rough at idle and smooths out when im driving. Seems to have its power back although I didnt want to beat on it too much. speedo was jumping around at some points and one time it felt like my trany was slipping but didnt do it again. If anyone could tell me what might cause this, Im tired of not having my car on the road.
  2. #2 Re: Fixed broken valve spring, Still misfiring
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    man dude. something sounds effed up. Bill might be your guy to help you. hopefully you tried the stuff we all listed before and if none of that was it...then idk.
  3. #3 Re: Fixed broken valve spring, Still misfiring
    Jan 1970
    Maquoketa, Iowa
    bent valve?
  4. #4 Re: Fixed broken valve spring, Still misfiring
    ^^That is what I'm thinking...
    Like I stated before...rent or buy a borescope and try to check out the piston to see if there is damage there...
  5. #5 Re: Fixed broken valve spring, Still misfiring
    Acworth, Georgia
    Checked the compression.and when i first turned it over i got 80psi then i tried again and got like 60. Third time like 10. Tomorrows another day to try and fix this thing.
  6. #6 Re: Fixed broken valve spring, Still misfiring
    St. Louis
    Time for a headswap! You probably trashed a valve and it's not closing all the way, hence the bad compression readings and strange idling.
    Hopefully you didn't take the piston w/ it.
  7. #7 Re: Fixed broken valve spring, Still misfiring
    SE Level Member Freimuth's Avatar
    Nov 2009
    Clinton, Ohio
    I would agree sounds like a bad valve. Pull the heads..
    New to me ---- 1999 Grand Prix GTP 216K miles and counting
    SOLD----1997 Grand Prix SE 3.8 -- 1K miles from the 200k club.
  8. #8 Re: Fixed broken valve spring, Still misfiring
    Might as well get head studs while your in there...it makes life pretty easy if it ever happens again...and while the heads are off...get em ported!
  9. #9 Re: Fixed broken valve spring, Still misfiring
    Acworth, Georgia
    So the heads off and the valve looks fine. Gaskets all look fine. What the hell could it be?
  10. #10 Re: Fixed broken valve spring, Still misfiring
    Acworth, Georgia
    They are ported already
  11. #11 Re: Fixed broken valve spring, Still misfiring heads are off
    Acworth, Georgia
    valves are straight and are seating properly. Could it be something else? im almost thinking about putting it all back together and seeing what happens. on a good not i ported my supercharger finally.
  12. #12 Re: Fixed broken valve spring, Still misfiring heads are off
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    Got a lazy injector? Did you test another hole with the compression tester to make sure the compression tester was reading true? I would have also done a Cylinder Leak Down test before I pulled the head..would have told you if you have a valve not seating, bad head gasket/cracked head, excessive ring ware..
    What do the walls of the cylinder look like?
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  13. #13 Re: Fixed broken valve spring, Still misfiring heads are off
    Acworth, Georgia
    I did try the compression tester on the other cylinder and got about 90 PSI if i remember. The walls of the cylinder look good and when I replaced the spring valve for my broken exhaust one, When I filled the cylinder with air it held it at about 100 psi with no leaks.
  14. #14 Re: Fixed broken valve spring, Still misfiring heads are off
    Ontario, Canada
    I would be looking at an injector problem or coil issue. Try switching 2 coils around and see if the problem follows the coil or stays with the cylinder.
    Jay
  15. #15 Re: Fixed broken valve spring, Still misfiring heads are off
    Acworth, Georgia
    I did switch the coil and it was still cylinder 5. I havnt swapped the injectors but I did ohm them out and they checked out god. Tomorrow ill be putting her all back together so Ill see if its fixed or not.
  16. #16 Re: Fixed broken valve spring, Still misfiring heads are off
    Jan 1970
    Maquoketa, Iowa
    pushrod/lifter looks fine?
  17. #17 Re: Fixed broken valve spring, Still misfiring heads are off
    Feb 2009
    flintnasty MI
    Seems like you could have borked the rocker as well.
  1. Cylinder 5 misfire UPDATE Broken valve spring
    By Kasey in forum General Tech Discussion
    Last Post: 09-12-2011, 07:32 PM
  2. Bent pushrod and broken valve spring?
    By brokenmercy in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-07-2011, 05:31 PM
  3. Loose Ignition Key, Broken Spring?
    By Stormwolf in forum Engine
    Last Post: 10-25-2010, 06:29 PM
  4. Broken Spring
    By pski920 in forum Brakes/Suspension/Chassis
    Last Post: 06-22-2009, 10:53 PM
  5. misfiring?, hesitating? valve lash?
    By icolex1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-26-2009, 08:03 AM
