Thread: new pcm?
Results 1 to 8 of 8
  1. #1 new pcm?
    regina
    i have a 97 gp with the 3800 the abs light came on and the speedo died a day later i changed the vss checked the gauges and tested the wiring for continuity all seems good the only thing i can find is the pin on the ecm for the speedo is grounded im thinking a short in the ecm i know the computer is 97 only but im wondering if one from an olds Intrigue or a bonnevile would work just to see if that is the problem? the car shifts fine if i unplug the vss it wont shift im at a loss any other ideas would be apreciated!!!
  2. #2 Re: new pcm?
    Charles City, IA
    Needs to be a 97 grand prix pcm.
    SMGPFC Two Nipple General
  3. #3 Re: new pcm?
    SE Level Member Wisconsingrandprix's Avatar
    Aug 2011
    roun here
    could it use a 98??
  4. #4 Re: new pcm?
    nope, 97 is different than 98+
  5. #5 Re: new pcm?
    Aug 2011
    roun here
    How so? The onlything different is the trans right~¿
  6. #6 Re: new pcm?
    97 pcms are bigger, have different files and yes the trans is different for 97 GT's because its a vacuum trans.
  7. #7 Re: new pcm?
    Aug 2011
    roun here
    Could I throw one of thoes bidges in my 98? Is it a dif harness?
  8. #8 Re: new pcm?
    Why?
    stick with the 98-02 pcm's.
pcm
