Thread: steering gear
Results 1 to 14 of 14
  1. #1 steering gear
    SE Level Member sweetgtx98's Avatar
    Aug 2011
    wisconsin
    i was told i need a new steering gear, is that located in the power steering rack?? and why so dam expensive for part ?
    12.75 @ 108mph 1/4
  2. #2 Re: steering gear
    I didn't know our cars had steering gears. I know there is a steering rack.
  3. #3 Re: steering gear
    Likely your diagnoser needs to clarify their diagnosis of the issue. Not sure how we can help beyond telling you it might be a rack, tie rod or a bad guess on the diagnoser's part.
  4. #4 Re: steering gear
    Aug 2011
    wisconsin
    bill it was at a local, good dealership, they said i need new steering gear w/variable steering, they have a part number listed here,26079912, it supposdly @ end of steering column, sorry about spelling!! they have the part listed as $850.00,dam,thats without labor!!
    12.75 @ 108mph 1/4
  5. #5 Re: steering gear
    Soooo it is Never heard it referred to as that.
    Googled it, found the part number with a picture. Picture is of what we would all call a rack. which splains it. They gave you the "technical" name for it.
    W STEERING GEAR ASM (NV7,NV8); W STEERING GEAR ASM (NV8); W STEERING GEAR ASM POWER; W STEERING GEAR ASM POWER(NV7); WB,WF STEERING GEAR ASM POWER; WB,WF,WY STEERING GEAR ASM POWER;. Fits: Century, Grand , Intrigue, Regal | Nalley Buick GMC Brunswick
  6. #6 Re: steering gear
    Aug 2011
    wisconsin
    ok, thanks bill, normally doesnt that come with the steering racks?
    12.75 @ 108mph 1/4
  7. #7 Re: steering gear
    The part number points to the whole rack assembly. I think it's technical name is steering gear per the illustration and decription.
  8. #8 Re: steering gear
    Aug 2011
    wisconsin
    ok, thanks again bill
    12.75 @ 108mph 1/4
  9. #9 Re: steering gear
    if you feel like saving 750 bucks heres the how to, for rack removal,http://www.grandprixforums.net/04_rack_replacement.php
    i got a used rack for 75 bucks, most junk yards want 100 to 125 for them, it took about 4 hours to do, start to finish, its not that its so hard to as the bolts are in some what tight areas, but well worth saving all that money if you feel this is something you can do yourself. i think in all its 17 bolts, 10 of witch are lug nuts for the tires lol
  10. #10 Re: steering gear
    Aug 2011
    wisconsin
    thanks for the link scottydoggs!!!, and yea i plan on haven a friend help with the install!! i got a used one from a friend pretty cheap!!
    12.75 @ 108mph 1/4
  11. #11 Re: steering gear
    Quote Originally Posted by sweetgtx98 View Post
    in that case ill let you know that you dont need to remove the master cylinder, or the air box like it says in the write up. you can get the power steering lines from underneath the driver side of the car, bolts on the lines are 18 mm line wrench. drop the back of the cradle 2 to 3 inches for extra room, you'll need it.
    and dont spin the steering wheel around, lock the wheel and leave it alone, if the wheel is spun the clock spring will break and then the air bag light will come on.
  12. #12 Re: steering gear
    Aug 2011
    wisconsin
    thanks for the heads up scottydoggs!
    12.75 @ 108mph 1/4
  13. #13 Re: steering gear
    i also locked my steering wheel with the wheels straight, also when you unbolt the tie rods, leave the old jam nuts on. when i got mine out i laid the old and new one up side by side, i tried to match everything up, the way the nub comes out of the top of the rack to the steering shaft, get that as close as possible, makes getting the new rack to line up so much easier, and try to match up the jam nuts for the tie rods as well, the shop told me i was damn close when i went in for alignment.
    i also de greased the whole engine, trans, and under side of the car, i put the car up on ramps and had at it, clean cars make happy mechanics.
    you wont believe whats under there till your arms deep into black grim every where.
  14. #14 Re: steering gear
    Aug 2011
    wisconsin
    just pick up a used rack, looks to b in good shape, alittle dirty, will have to clean it before installing, it came with the power steering fluid container and pump and pully and all hoses,, it's probally easier to just do rack and use my pump and reseivor thats on my car already?? and thanks for the help guys!!
    12.75 @ 108mph 1/4
  1. 2nd gear to 4th gear shift
    By 98grannyprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-17-2011, 01:03 AM
  2. 02 GTP no 4th gear
    By dtun1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-02-2011, 08:07 PM
  3. Steering Gear
    By emoeller in forum Brakes/Suspension/Chassis
    Last Post: 12-16-2010, 12:24 AM
  4. rev gear bad.
    By clevelandfan in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-05-2010, 12:48 AM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
