Thread: interceptor scangauge
Results 1 to 11 of 11
  1. #1 interceptor scangauge
    SE Level Member tcafego's Avatar
    Aug 2011
    taylor, mi
    Which model aeroforce interceptor scangauge do I need for my 98 grand prix gtp?
  2. #2 Re: interceptor scangauge
    email them and tell your car info and they will send you the one you need, they program it for you.
  3. #3 Re: interceptor scangauge
    Omaha, NE
    1997-2007 Grand Prix (PT)
    ZZ Performance
  4. #4 Re: interceptor scangauge
    Aug 2011
    taylor, mi
    So if I get a 3 pillar pod, what other 2 gauges do u guys recommend getting?
  5. #5 Re: interceptor scangauge
    boost/vac
    oil pressure
    wide band (for higher modding)
  6. #6 Re: interceptor scangauge
    Houston
    I went with boost/vac and oil pressure
  7. #7 Re: interceptor scangauge
    Omaha, NE
    3 interceptors.
  8. #8 Re: interceptor scangauge
    Aug 2011
    taylor, mi
    Ha 3 interceptors is what, $700+?
  9. #9 Re: interceptor scangauge
    SE Level Member kurt5153's Avatar
    Apple Valley,Ca 92308
    Keith~ where did you hook up ur gauges to for power? I'm having issues finding power offvyhe ignition. Thanks
  10. #10 Re: interceptor scangauge
    Houston
    Quote Originally Posted by kurt5153 View Post
    Under the driver dash you should see this. The red will be constant 12v and pink will be switched 12v
  11. #11 Re: interceptor scangauge
    koo thxs
  1. Wiring an Aeroforce Interceptor Scangauge
    By Warbeaver in forum How To Write-Ups/Tech Tips
    Last Post: 1 Week Ago, 08:48 AM
  2. scangauge II vs. aeroforce interceptor
    By kyle99gtp in forum General Tech Discussion
    Last Post: 06-25-2008, 09:48 PM
