Thread: whining/screechy/annoying noise
Results 1 to 15 of 15
  1. #1 whining/screechy/annoying noise
    SE Level Member mousemonster1232's Avatar
    Surprise, AZ
    So recently there has been a whining type noise (not supercharger) that is happening in my 99 gtp. It is happening from about 700-1500rpm usually... my brother first thought it was a bearing on the engine or. Pulley. Father thought fuel pump. But I narrowed it down to mainly from drivers front.
    Any suggestions? Thanks.
  2. #2 Re: whining/screechy/annoying noise
    you can try removing the belts to see if it stops. then you know its a pulley.
    does the noise rise up and down with the engine rpm's? if its loudest on the driver side it could be a transmission pump going bad. lets hope for a pulley.
    and does it do this parked, driving or both?
  3. #3 Re: whining/screechy/annoying noise
    Surprise, AZ
    Its from drivers side. Almost positive. It does it parked and driving. It goes somewhat increasing with the rpms
  4. #4 Re: whining/screechy/annoying noise
    how high are your miles? was the trans ever serviced, is the fluid burnt up/brownish?
  5. #5 Re: whining/screechy/annoying noise
    Surprise, AZ
    189k. And not since I've owned it. So I'm unsure of the transmission oil condition.
  6. #6 Re: whining/screechy/annoying noise
    check your fluid. if its all brown and cooked up,(use a white paper towel to wipe off the stick) take it to a shop and see what they say. unless you rebuild transmissions. most of us dont.
  7. #7 Re: whining/screechy/annoying noise
    Is it a belt squealing?
  8. #8 Re: whining/screechy/annoying noise
    Surprise, AZ
    It doesn't seem as though it is a belt. It is coming from the driver's side where no belts are located. I could be incorrect though. And I can check the fluid (hopefully tomorrow, before it gets too far out of hand).
    And no, I do not rebuild transmissions, unless it is the real ancient kind that are for RWD. hahaha. And even then, it's more like ----rigging it, not rebuilding.
  9. #9 Re: whining/screechy/annoying noise
    Surprise, AZ
    I just checked the fluid. The "fluid" itself, I THINK looks okay. I'm not sure though, I do not think this black stuff came from the fluid, I think it was from the metal of the dipstick. Perhaps you tell me your guess! Pictures below.
  10. #10 Re: whining/screechy/annoying noise
    That is dirty fluid. Not trashed dirty, but dirty as in .. should probably service it if you haven't.
  11. #11 Re: whining/screechy/annoying noise
    new britain, ct
    have you checked your power steering fluid? i remember my car was "whining" once and i just needed some power steering fluid.
    07 Black GXP.
  12. #12 Re: whining/screechy/annoying noise
    Surprise, AZ
    Okay after taking forever to find the da-- power steering pump reservoir in the 110 degree heat here in AZ, I can't get it off because the car is too hot.. I will check it after the engine cools. And I will check around to see about how much it costs for ATF change.
    Aside from that, I noticed there is a clicking noise now, and I see that every time the belt goes around it is in the same spot where one of the tensioners clicks like gives a little slack and then pops back. How could I correct that?
    My car is going downhill! AHHHH.
  13. #13 Re: whining/screechy/annoying noise
    Omaha, NE
    A new tensioner and belt should take care of that.
  14. #14 Re: whining/screechy/annoying noise
    Texas
    Sounds more like the Torque convertor.
    85 Corvette
    01 TA
    03 Z06
  15. #15 Re: whining/screechy/annoying noise
    Ocala, FL
    Quote Originally Posted by ctracer View Post
    That sound would get louder when he was turning at low speeds, especially when turning the wheel with the car stopped. So I would doubt it was that, unless he notices that.
  1. Whining Noise?
    By BwolfGT in forum General Tech Discussion
    Last Post: 06-15-2013, 09:44 PM
  2. 04 with whining noise from speakers?
    By white trx450er in forum Audio, Security & Visual Electronics
    Last Post: 06-06-2011, 03:23 PM
  3. Supercharger Whining noise very loud
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2011, 07:25 AM
  4. Whining Noise
    By silo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:50 AM
  5. Whining Noise
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-02-2009, 11:23 AM
