Thread: Code p0300 misfire caused by cat?
Results 1 to 4 of 4
  1. #1 Code p0300 misfire caused by cat?
    Sep 2011
    canyon texas
    I read a post about a clogged cat. Is there a way to check?
  2. #2 Re: Code p0300 misfire caused by cat?
    Omaha, NE
    Misfires are usually spark related.
    Your cat can get clogged. If you search, there are quite a few threads on that.
  3. #3 Re: Code p0300 misfire caused by cat?
    Pull the upstream O2 out and put a pressure gauge in it and see if it has any pressure. Shouldn't have more than 1-2 psi
  4. #4 Re: Code p0300 misfire caused by cat?
    Charles City, IA
    Just pull the up stream 02 and go for a drive and see if the miss goes away.
    SMGPFC Two Nipple General
  1. Sputtering and P0300 code
    By grngt97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2010, 02:12 PM
  2. Horrible misfire under heavy load: P0300, and P0171
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2010, 06:28 PM
  3. random misfire P0300, many new parts
    By MarkB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2009, 11:10 PM
  4. P0300 multiple cylinder misfire code
    By Reeddawgy in forum PCM Tuning
    Last Post: 07-15-2008, 07:42 PM
  5. Removing P0300 misfire code side effects....
    By Trannyman95 in forum PCM Tuning
    Last Post: 07-11-2008, 12:29 PM
