Thread: No tail lights but brakes work just fine??
Results 1 to 7 of 7
  1. #1 No tail lights but brakes work just fine??
    Aug 2011
    Phoenix, AZ
    Hello! I have an 07 grand prix and for some reason both my tail lights stopped working but my brake lights work just fine. I examined both fuse boxes and there is nothing on either about tail lights!!! Is there a fuse I should look at and are there other possible problems? Driving illegally with these lights so any help ASAP would be fantastic!
    Thanks
    Chris
  2. #2 Re: No tail lights but brakes work just fine??
    Omaha, NE
    Yes there's a fuse. Refer to your owners manual for the location.
  3. #3 Re: No tail lights but brakes work just fine??
    have you checked the bulbs yet?
    and their should be a fuse for the parking lights or tail lights.
  4. #4 Re: No tail lights but brakes work just fine??
    Aug 2011
    Phoenix, AZ
    I havent checked the bulbs yet. Is it likely they all burnt out at once? Also I was referring to the manual and I can say confidently there is nothing that says tail lights or anything similar. Is there another label theyd be under?
  5. #5 Re: No tail lights but brakes work just fine??
    Aug 2011
    Phoenix, AZ
    Or at least could you tell me if the aPpropriate fuse box is the one under the hood or the one on the passenger interior? Im just sitting here waiting to drive home because I dont want to be pulled over.. Haha thanks
  6. #6 Re: No tail lights but brakes work just fine??
    Omaha, NE
    You didn't find the term "fuses" in your owners manual? You may want to look again.
    The fuse you need should be on the passenger side of the dash. Behind a little door. On that door there should be labels for what fuse is where.
  7. #7 Re: No tail lights but brakes work just fine??
    Aug 2011
    Phoenix, AZ
    What im saying is the fuse isnt labeled... I have retained accessory power, sunroof, cruise switch, parking lamps, rear defog, door lOck/trunk, onstar, fuel tank solenoid, parking lamps (again?), radio, keyless entry, hud, int lamps, climate control, back up lamps, power windows, steering wheel switches, power seat, turn signals, power mirrors and heated seat
  1. Drive & 3rd Dont engage, 1,2 and Reverse work fine
    By HomeBoyShopnClub in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-25-2009, 12:17 AM
