Thread: Car not turning over...
Results 1 to 15 of 15
  1. #1 Car not turning over...
    GT Level Member Bogers04SS's Avatar
    Feb 2010
    Mocksville, N.C.
    I finally got the SS back together from the re-build, now it wont turn over. I've got every wire connected, all grounds in place just wont't hit a lick. I have a diagnostic scan tool, (Auto X-ray), but it is not responding to the vehicle. All the gauges, radio, lights work fine, but when I try to crank it, everything turns off. Then a few moment s later it all comes back on. I've already replaced the ignition switch cylinder and ignition module hoping that might be it, but no such luck. My last 2 ideas are either the PCM or BCM..... Just seeing if there might be anything else before I have it towed to the "Stealership". Any help would be great!
    04 Impala SS -- SOLD
    08 Prix GXP -- FWI, 3in DP, TR6IX plugs, Ported & polished throttle body, ported intake manifold, DiabLEW Tuned, wrapped crossover pipe, Cat delete, Factory res., Muffler delete, Poly motor mounts, shift kit, LED bulbs in just about every Da*n thing, ect..
  2. #2 Re: Car not turning over...
    Charles City, IA
    Doesnt turn over or fire?
    SMGPFC Two Nipple General
  3. #3 Re: Car not turning over...
    Omaha, NE
    And what did this rebuild consist of? What have you changed since it ran last?
  4. #4 Re: Car not turning over...
    Feb 2010
    Mocksville, N.C.
    Quote Originally Posted by TheOtherNick View Post
    Not turning over
  5. #5 Re: Car not turning over...
    Charles City, IA
    battery dead?
  6. #6 Re: Car not turning over...
    Feb 2010
    Mocksville, N.C.
    Putting a piston back in that had MAJOR detonation issues (i.e ripped half the skirt off the piston and chipped the top of the piston). Other than the new piston, rings, all new gaskets and new plugs, just a new ignition cylinder switch and a new ignition module.
  7. #7 Re: Car not turning over...
    Feb 2010
    Mocksville, N.C.
    battery dead?
    Battery has been fully charged
  8. #8 Re: Car not turning over...
    Does it just click and then nothing?
    I'd say triple check the order of the grounds on the starter and transmission.
  9. #9 Re: Car not turning over...
    Feb 2010
    Mocksville, N.C.
    Nothing clicks, everything turns off and then comes back on a few seconds later......maybe have to re-check grounds under the car.
  10. #10 Re: Car not turning over...
    Feb 2010
    Mocksville, N.C.
    I can bump the starter by crossing over with a screw driver, it spins, but wont crank.
  11. #11 Re: Car not turning over...
    St. Louis
    This sounds like a loose battery connection or loose cable. My 00 GT did exactly this when the neg. side was just the slightest bit loose.
  12. #12 Re: Car not turning over...
    Feb 2010
    Mocksville, N.C.
    Quote Originally Posted by FordMan77 View Post
    I checked all grounds this morning and did notice the neg. terminal was stripped, so I replace it. Didn't change anything
  13. #13 Re: Car not turning over...
    At the starter there's the cable plus two wires that share one grommet that are hooked to the post with teh 13mm nut. The grounds are one battery cable and two individual grommeted wires that get held to the transmission bolt.
    It sounds like you have one or so missing. Not that I'd know from experience.
  14. #14 Re: Car not turning over...
    SWPA
    Quote Originally Posted by Bogers04SS View Post
    If it just spins the starter then you are not completely crossing it over. It sounds when you are crossing it over the bendix is not popping out to engage the flexplate.
  15. #15 Re: Car not turning over...
    could be a bad starter solenoid. thats what makes the gear pop out and engage the fly wheel.
    and in a lot of cars if the starters not hooked up, nothing lights up, and all the wires go to the solenoid on the starter.
  1. Car wants to die while turning
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2011, 10:32 AM
  2. Air bag not turning on
    By izup69 in forum 04+ Specifics
    Last Post: 03-13-2011, 05:56 AM
  3. turning off headlights
    By chickenfried in forum General Tech Discussion
    Last Post: 06-12-2010, 12:22 PM
  4. Turning a 01' SE into a GT
    By Dangerous313KidInAPrix in forum Visual/Body Modifications
    Last Post: 03-03-2009, 09:17 PM
  5. TCS not turning off
    By Keet04GTP in forum General Tech Discussion
    Last Post: 08-06-2008, 02:57 PM
