Not so much the IAT sensor becuase you can have warmed up car and show cold numbers in a cold climate, The coolant tem sensor (CTS) will tell the computer the coolant temp is below normal operating range. Basically all the sensors work together, the computer uses a mathmatical calculation based on the sensor readings to arrive at an injector pulse width given the operating conditions.
