where to start. ok so i have a 2000 grand prix gt. i was looking for a little more power, so i did the ss m90 kit from zzp. got the power but now, i have a few issues.
the first issue i have dealt with for quite some time since the upgrade is this weird delay in throttle response. its actually quite annoying, and it seems as if NOBODY can figure the problem out. i can explain very precisely what happens:
when the car is cold, i will give it some gas, and the rpms will drop, and almost die, but then it will rev high above 1grand for a bit, then drop back to a little bit above 1grand(normal rev for cold engine as many of you know). ok, so i start driving, and through each of the gears, the rpms dont go up steadily but kind of "notch" their way up(hopefully that made sense). when the car shifts, the rpms drop even as i step on the gas. however, once the car has warmed up, i no longer have this "lag" issue. any suggestions?
the next issue is some codes i have thrown. thanks to my aeroforce intercepter scan gauge, i have not had to go to the dealer to get the codes. i throw a p1133 code on a regular basis(weekly), and every once in a while a p0300 code (monthly). since the p1133 code is "bad o2 sensor," we swapped out the front sensor, and it was fine for a while. but i still throw the code on a weekly basis. any suggestions for me to quit throwing these codes? i am not sure if it has anything to do with the codes, but the grand prix has also seemed to have lost a little bit of power. i feel as if the codes are part of the problem.
if anyone has ANY sort of idea to help me out, i would greatly appreciate it. these problems dont seem critical, but are very annoying :\
i am also looking to upgrade my head lights. i need new housings for sure, cuz mine are fogged out. has anyone done the HID conversion? it looks tight
