Thread: Running safe?
Results 1 to 20 of 20
  1. #1 Running safe?
    Donating Users kyleinkman's Avatar
    May 2011
    canada
    hey thanks for taking the time to check this out.
    im just wondering if im running all my mods correctly and safely, blue ive already used ur safely modding thread but i wanna double check
    Mods:
    pacesetter headers
    3 inch pipe
    catless
    flowmaster super 44s
    k&n Intake
    Egr delete
    Air screen in intake delete
    flipped mounts
    Cooler NGK plugs
    NGK wires
    3.4 pulley
    MODS:
    K&N Intake, Removed mesh air screen, flipped mounts, egr delete, NGK Cooler plugs, NGK wires, 3" pipe, Pacesetter headers, Flowmaster super 44's , 3.4 pulley, 18 inch Fast wheels rims, NanKing ns II tires, Overkill tune, comp cams. junk yard short block
  2. #2 Re: Running safe?
    Waukesha, WI
    looks right, have anyway to scan to see if your knocking?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #3 Re: Running safe?
    Charles City, IA
    remove the intake screen will cause issues.
    3" pipe will be annoying
    You need a good tune
    k&n intake is a waste of money
    SMGPFC Two Nipple General
  4. #4 Re: Running safe?
    Did you scan?
    Because none of that matters unless you scan and you've checked your AFR under various conditions.
  5. #5 Re: Running safe?
    well then
    i was gonna say something about scanning it but i got jumped..not just once but 3 times...damn
    SMGPFC Member #10
  6. #6 Re: Running safe?
    May 2011
    canada
    the only scanner i have is a basic code reader, i was thinking of getting the tuned pcm from zzp any comments on it?
    MODS:
  7. #7 Re: Running safe?
    Where in canada are you?
  8. #8 Re: Running safe?
    Waukesha, WI
    no zzp, go with overkill, 3800perf, or intense
    RayRay
    92 Turbo miata
    02 lexus is300
  9. #9 Re: Running safe?
    May 2011
    canada
    pembroke about 45 min from ottawa
    MODS:
  10. #10 Re: Running safe?
    Ah true.
    I believe there are a few guys trying to convince Will (Overkill) to come to Ottawa for a tuning weekend or something to that effect.
    Might want to check out OQCGP.com for that.
    Also put that screen back in, the flow increase isn't worth the inaccuracy in MAF readings.
  11. #11 Re: Running safe?
    May 2011
    canada
    where r u from matt?
    MODS:
  12. #12 Re: Running safe?
    Real close to Toronto.
  13. #13 Re: Running safe?
    May 2011
    canada
    know any good parts sites that doest kill us canadians in shipping?
    MODS:
  14. #14 Re: Running safe?
    Nope.
  15. #15 Re: Running safe?
    My thread also does not recommend aftermarket mufflers, HUGE useless catback piping, and K&N FIPK's.
    Make your own intake...less than $50.
    Pacesetter's suck unless you plan on putting another $50+ in them to get them welded...buy Speed Daddy's off of EBay for less than $200 and have a new flex put in it. For the 3.4", hopefully your not talking press-on...because that's a nice paper weight...just get ZZP's MPS...and order a 3.6". Then you really wouldn't have to ever worry about scanning...there, I said it.
  16. #16 Re: Running safe?
    My understanding is the list mentioned is what has been done.
  17. #17 Re: Running safe?
    I thought he hasn't installed them yet, oh well...reading plays a huge part.
    I b hypocrite.
  18. #18 Re: Running safe?
    Its okay...
    You'll read one day.
  19. #19 Re: Running safe?
    I read that^
  20. #20 Re: Running safe?
    I would not run 3" strait pipes to flomaster 44's without at least a catback. I do not like the sound of flowmaster 44's on any car.
    I'm thinking of going to a junk yard and getting the stock cat-back off one of the gps they have my car sounds so much like **** at WOT idle and cruising it sounds alright.
  1. Safe to Run 3.0 Again?
    By Hixc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2011, 10:14 PM
  2. safe??
    By wlmrt6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2010, 01:58 AM
  3. Is running lean safe?
    By BwolfGT in forum Off Topic Discussion
    Last Post: 10-13-2009, 07:46 PM
  4. Safe to run 3.2?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 09-25-2009, 11:20 AM
  5. Is running a universale intercooler on my 04 GTP safe?
    By ncccgolf5 in forum Off Topic Discussion
    Last Post: 09-08-2009, 10:53 PM
