Is there any other model of GM car that has interchangeable parts with a 99 GTP? I have the digital A/C controls and would like to switch them out with a different looking model, like the Bonnie's. Anyone know if i can do this?
Thanks.
Thanks.
Even if it fits, you'll probably have to do some custom wiring to make it work.
You never know though, it could be plug and play...
Yeah, I'm hoping there are some other controls that will be...
I dont think you will be able to do that, It would most likey require a complete harness overhaul/replacement.
What your looking at is kinda the same thing as guys wondering if they can switch between the digital hvac and the knob hvac controls, and that cant be done because of the harnes's.
I figured as much. Oh well. Thanks guys.
You might be able to change over to the other W body control heads.
Monte Carlo/Impala, Intrigue and Century/Regal are built on the same platform.
The electrical architecture is common, but you will need to compare connectors and, as already mentioned, you might need to re-configure the harness.
