Thread: My reason for demodding - Transmission
Results 1 to 11 of 11
  1. #1 My reason for demodding - Transmission
    Some of you know that I went through a bunch of built up transmissions. Let me kick out some basic info first and bring you up to speed.
    Bought a 97 Bonneville and was not going to mod it. My dickbag friend told me about an ebay auction for a pulley and puller, that was the end of stock.
    Final build on the motor:
    Stock bottom end
    S1X camshaft
    PRJ S3 heads (stock gaskets, arp stud kit)
    130# springs (fresh valve seals)
    Titanium retainers
    HD locks
    1.8 HS rockers (comp bolts)
    Ported LIM with coolant mods (see prepping an LIM)
    Meziere EWP
    Bonneville PS relocation bracket (moves ps back 1-1.5 inches for better belt path with EWP)
    8 Rib SC belt and pullies
    WBS S3 IC
    Gen V with 2.9" pulley
    Northstar TB
    4" FWI
    SLP headers
    Aluminum Bonneville oil pan, pickup tube and filter adapter (2000-2003)
    42.5lb injectors
    PRJ fuel rails
    PRJ plug wires with labels and protective boots
    Oversized El Dorado radiator
    2000 Bonneville Alt bracket and alternator with voltage sense added
    258mm flex plate drilled for 245mm.
    Trans
    Fully built each time.
    Intense input shaft
    3.29 gearset with 7/8 chain
    hardened 4th hub shaft
    Tightened up clutch packs
    Upgraded/New valve body and channel plate
    245mm torque converter
    The problem
    I ended up building two different transmissions for this car. The first one was out 6 or so times to be fixed. Each time the Input Shaft reluctor was ripped off the drive gear. This includes the recluctors that were screwed on by Intense, stockers and the tighter drilled one from TEP. In the three builds, the 7/8 chains were stretched. The last one being the lowest mileage (~2K miles total) and the worst of all.
    Here's some pics.
    One reluctor
    The corresponding channel plate that it dug up
    Next
    The last trans I built
    2K miles later
    The chain where my finger is..should be at least 1/8" from the case. To reuse per the ATSG manual. It was easy to bottom it out.
    It dargged
    When I felt the noise after the upteenth rebulld I said I was demodding and done building a 3800 in one of my cars. I'm currently driving a mild Regal with a set of rockers and after it's first transmission (189K miles) I will put a Gen V on it. That's as far as it will ever go.
    I am considering asking the machine shop if they can weld the reluctor onto the drive gear to keep this from ever happening again in my "mild" setup.
  2. #2 Re: My reason for demodding - Transmission
    GT Level Member RegalGS98s's Avatar
    NJ
    I think some of that happened because a Bonneville weighs about 4000 lbs vs a Regal (~3600 lbs) vs a 2 door GTP ~3300 lbs. I'm sure your foot didn't help either, lol, but I think it was the weight of the car. Surprised they didn't put the 4t85E or whatever's in a Cadillac Deville or STS. My friend keeps telling me I should get an adapter to put that transmission in instead.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  3. #3 Re: My reason for demodding - Transmission
    I live here. TLSheff's Avatar
    *Final picture text says "It Dargged" <--- fix that
    As to your tranny problem, I seem to recall a video that you described as a "Banshee under the hood" as you went under bridges in the SSEi Sure those highway pulls didn't help any
  4. #4 Re: My reason for demodding - Transmission
    Weight of the car shouldn't have anything to do with the reluctor, which was the actual failure point. The chain, well.. likely it was a factor.
    BTW your weight numbers are off by a bit. With me in the car a the track it was 3800lbs.
  5. #5 Re: My reason for demodding - Transmission
    GTP is 3500
  6. #6 Re: My reason for demodding - Transmission
    GTP is 3500
    Coupe or Sedan?
    I know there is only a couple hundred lbs difference between them, figured 3500 for Sedan and 3300 for Coupe was about right
  7. #7 Re: My reason for demodding - Transmission
    Couple hundred?
    Theres about a 20 lb difference.
    You'll see some 3394 figures......... but they're for cars with 3.1's.
    Soon as you step into the 3800 you're in the mid/high 3400's.
    Throw on a blower and you're 3500, add some features here or there.... 3550.
  8. #8 Re: My reason for demodding - Transmission
    NJ
    It must depend on the sources. Those are the numbers I remember from cars.com a few years ago for 97-98 years, but they're not listed anymore for the older model cars now. The newer 99, 2000-2003 weighed a little more and then 2004 and newer was at least another 100 lbs for the 4 door compared to the 97-03. 1992-1999 Pontiac Bonneville: Full Review - Consumer Guide Automotive and 1997-2004 Buick Regal: Technical Specifications - Consumer Guide Automotive both list 3446 lbs for the Regal and Bonneville so I don't think that's right. Regal was about 3650 and a 4 door Grand Prix was about 3500 lbs. It seemed to go up in steps of 150 lbs cause the 2 door GTP was about 3350. I remember making a post here before with a list of weights or some measurement I compiled, I'll have to look.
  9. #9 Re: My reason for demodding - Transmission
    Portland Oregon
    Geeze Bill, way to scare me about a trans for my GTP lol.
  10. #10 Re: My reason for demodding - Transmission
    check your doorstamps.
  11. #11 Re: My reason for demodding - Transmission
    NJ
    Might work using the GVW. I think it's 1,000 lbs capacity for most cars so minus that to get the curb weight. Bill, did you figure what your reluctor wheel was catching on. I need to get working on by trans build soon (already have the parts) and I'm trying to make any improvements where needed.
  1. The Reason That Your Transmission May Act Up After a Flush
    By njbrain in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2008, 07:53 AM
