Thread: pcm talk
Results 1 to 14 of 14
  1. #1 pcm talk
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    I never messed around with the computer stuff in cars before. ive heard in a few threads about the pcm "pull timing"
    what exactly happens when it pulls timing?
    delayed valves or delayed fuel injection? idk. just woundering.
  2. #2 Re: pcm talk
    It means it pulls ignition timing when your car knocks (KR)...when you don't have enough flow mods...meaning...your car is slow then.
  3. #3 Re: pcm talk
    so basically your pulley should be sized based on how your motor responds to mods.
    not the other way around.
  4. #4 Re: pcm talk
    Jul 2011
    Michigan
    oh, so its kr related. gottcha, no further explantiaon required.
    thanks.
    and im n/a
  5. #5 Re: pcm talk
    apparently: cam, flow more, set timing at 28, run 87 octane.
  6. #6 Re: pcm talk
    Jul 2011
    Michigan
    wait, were not done lol. what does 28*of timing mean. sorry. and i did try and google it.
  7. #7 Re: pcm talk
    Timing is at what point in the compression stroke the PCM tells the ICM to fire the coil for that cylinder. Which in turn fires the spark plug and detonates the compressed charge of air and fuel.
    The higher the timing, the more compressed the charge is and the greater the explosion from the spark.
  8. #8 Re: pcm talk
    The higher the timing, the sooner the fuel charge is set off.
    It has to be set off at the correct time to ensure maximum transfer of energy of the fuel into downward motion of the piston.
  9. #9 Re: pcm talk
    Er.. Don't you mean the higher the timing the more compressed the charge (aka further into the compression stroke and more powah)
    The more compressed, the bigger the bang.
  10. #10 Re: pcm talk
    Feb 2009
    flintnasty MI
    timing advance turns the spark firing to SOONER, which gets the burn started sooner, which gives you more VE.
    The problem with alot of timing, is it is obviously easy to go with too much timing.
  11. #11 Re: pcm talk
    Jan 1970
    Maquoketa, Iowa
    The lower the timing, the later the cylinder fires, less compression, less power.
    Knock is detected by knock sensors, pcm has tables that tell it what to do for each degree of knock and when to react. It will lower your timing (retard) but if you are getting too much knock, it may be too little too late considering how fast the motor is spinning and how fast the pcm is processing all of this.
  12. #12 Re: pcm talk
    why you say compression?
    Compression is static.
    The optimal time for pressure peak due to combustion is 20* ATDC.
    Give or take a few... as it does very much vary based on application.
    The issue is, fuel doesnt burn instantly. But thats a good thing.
    Otherwise it'd be like setting off a bomb in your cylinder.
  13. #13 Re: pcm talk
    Jan 1970
    Maquoketa, Iowa
    Because there is less compression at that moment in the stroke...
    Here:
    Trailer Park Boys :Rickyisms - YouTube
  14. #14 Re: pcm talk
    Why isn't he holding a glass of rye....
  1. Let's talk about oil
    By Rivmage in forum General Tech Discussion
    Last Post: 08-13-2011, 09:02 AM
  2. E85 Talk about a safety net!
    By OrangeL67 in forum General Tech Discussion
    Last Post: 07-17-2011, 11:08 PM
  3. Thats right Talk
    By JoshsGTP in forum Off Topic Discussion
    Last Post: 04-09-2011, 02:04 AM
  4. Don't Talk Sh!T
    By KawaFord in forum Off Topic Discussion
    Last Post: 11-26-2010, 11:41 AM
  5. Talk about a bad day
    By Deimos in forum Off Topic Discussion
    Last Post: 02-04-2010, 09:32 AM
