Thread: What size pulley is "TO SMALL"????
Results 1 to 16 of 16
  1. #1 What size pulley is "TO SMALL"????
    SE Level Member kenizzle36's Avatar
    Apr 2011
    Menasha, Wisconsin
    I was talking to a guy who said he has a 97 gtp with a 2.5 pulley on it. Didnt really give me a big list of supporting mods. Just sounds like that would be to small.
    99 GP GT- Bosal mufflers, Custom intake.
  2. #2 Re: What size pulley is "TO SMALL"????
    Probably for his car...its a ticking time bomb then...I'm running a 3.1" on plenty of timing...if I went back down to stock 16* I might get away with a 2.8". All I'd need is some E85 for a 2.5" or lower.
  3. #3 Re: What size pulley is "TO SMALL"????
    Korey pulled 18 psi right?
    10-13 psi seems to be the most you'd ever want to see.
    M90 prefers 7-8 PSI.
  4. #4 Re: What size pulley is "TO SMALL"????
    Apr 2011
    Menasha, Wisconsin
    Well I was talking to him about a job offer and he also offered me this car. SAYS its pushing around 400 hp, but after I heard 2.5 pulley I lost interest and didnt listen to the rest. If he ends up calling me Ill ask about supporting mods and see if this is something worth looking into.
  5. #5 Re: What size pulley is "TO SMALL"????
    If he gives it to you...sure...take it.
    Korey's car...had something wrong with it.
    No G3/G5 M90 makes 18psi unless there are HUGE flow issues.
    I make 11-12psi at the shift.
  6. #6 Re: What size pulley is "TO SMALL"????
    Oh, don't buy that car.
    Doubt the transmission is in good shape.
  7. #7 Re: What size pulley is "TO SMALL"????
    Apr 2011
    Menasha, Wisconsin
    He told me it has a rebuilt modded trans(dont remember what trans it was) with around 50k on it. Motor has 90k
  8. #8 Re: What size pulley is "TO SMALL"????
    If its FS...link us an ad or something...
  9. #9 Re: What size pulley is "TO SMALL"????
    Apr 2011
    Menasha, Wisconsin
    Not sure if he has it f/s. Hopefully he calls me soon(mainly because I want the job that will double my weekly pay) and Ill ask for a list of mods and such and Ill update.
  10. #10 Re: What size pulley is "TO SMALL"????
    GT Level Member RegalGS98s's Avatar
    NJ
    When I had the 1.84rr, SLP headers, stock L32 heads, and L26 bottom, I was getting 16 psi on a 3.25 pulley. I think my M90 is a Magnusson though, it has a keyway with a single bolt on the end to hold on the pulley. It's shaped like a Gen III, but the rotor coating is perfect. It would really scream. Can't say it was safe, think previous owner was also using Meth, but didn't tell me about it. But that's the PSI I was getting from the 3.25. The extra compression is the only restriction I could think of.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  11. #11 Re: What size pulley is "TO SMALL"????
    Quote Originally Posted by RegalGS98s View Post
    And it wasn't knocking on high compression? With just rockers and headers...even with Methanol...wow.
    And 16psi...yeah, that's nutzo
  12. #12 Re: What size pulley is "TO SMALL"????
    Out West
    16psi yikes.
  13. #13 Re: What size pulley is "TO SMALL"????
    Omaha, NE
    Aren't Whipples capable of stupid high PSI numbers without issue?
  14. #14 Re: What size pulley is "TO SMALL"????
    Because of the rotor design...
    BUT.
    Whipple's produce tons of heat...and to run one on a 3800 you need to have flow and cooling mods out the ass.
  15. #15 Re: What size pulley is "TO SMALL"????
    NJ
    Like I said, can't say it was completely safe, lol. At the time I didn't have a scanner to read KR or a tuner. It did run good, I messed with a Mercedes SL55 once. Could keep with him multiple times up to 135 or more, but couldn't pass him. Don't think I want to go that fast again. When I'm done my build, I'll have to see about KR cause I plan on using that M90 before building the M112. I'll have a few more flow mods than then so should see lower PSI. Still torn on NA or SC piston. Have to take some measurements of the rods and pistons when I get a chance.
  16. #16 Re: What size pulley is "TO SMALL"????
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    M90 efficiency at 16PSI is tits on a boar.
  1. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  2. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
