Thread: i seriously need some help guys
Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
  1. #41 Re: i seriously need some help guys
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    Ya I was thinking about what sensors control timing, not too sure at what times but here it is.
    Iat
    Map
    Cam sensor
    Crank sensor
    Knock sensor
    So I'm buying another pcm for my 97 just to rule that out and as kejross was saying, I'm gunna start throwing parts at it starting with the crank sensor. As for the intake back fires, I can kinda here it when it does it. Kinda sounds like a quite pffff sound when my boost guage needle spikes.
    If you start troubleshooting yeahright, post up what works and doesn't and ill do the same.
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  2. #42 Re: i seriously need some help guys
    Nov 2010
    south east AZ
    Hey there nice to hear from ya. That makes sense actually. it might just be cheaper to do that then keep buying sensors. It'll get expensive I just might have to do that. Thanx for that advise matt.
    Edited cuz I was thinking and typing at the same time
    01 T/A WS6-SOLD
  3. #43 Re: i seriously need some help guys
    Overland Park, KS
    If mine acts up anywhere near home next time I plan to jack it up & unplug the knock sensors temporarily to see if that has any effect. I'm getting one of those bluetooth OBDII adapters on order & the Torque app so I can at least watch sensor inputs to have a shot at diagnosing this thing.
    04 GTP Comp G, airbox cut, no cat or resonator
  4. #44 Re: i seriously need some help guys
    PA
    Haven't heard anyone suggest an LT4 knock module in awhile. If you computer doesn't work, that is a good way to see if you are picking up extra noise.
    See threads on the other forum:
    http://www.clubgp.com/newforum/tm.as...de=&s=#3273261
    http://www.clubgp.com/newforum/tm.as...de=&s=#4271773
    2001 GSE
  5. #45 Re: i seriously need some help guys
    Nov 2010
    south east AZ
    Cool thanx zef. Also ill be sending payment today for that pcm.
    01 T/A WS6-SOLD
  6. #46 Re: i seriously need some help guys
    PA
    Actually, I might have an LT4 knock module. If I do, I will send it along.
    2001 GSE
  7. #47 Re: i seriously need some help guys
    Nov 2010
    south east AZ
    Awesome thanx man
    01 T/A WS6-SOLD
  8. #48 Re: i seriously need some help guys
    GT Level Member GreyGhost's Avatar
    Nov 2009
    IL
    A cheap check would be to swap out the fuel filter. Have you put a fuel pressure gauge on it to see what it is running at? Check idle then rev it and watch what it does.
    Mine had this issue as well. Went with a catless DP and it helped for a bit then came back as mentioned above. Swapped out Fuel filters and it has been gone for about 30k now. Car has 280,000 miles on it.
  9. #49 Re: i seriously need some help guys
    Nov 2010
    south east AZ
    Well swapped pcm and knock module with no change in performance or driveability. It wouldn't hurt to check the fuel pressure but I'm getting ready to sell it for like 500 bucks. Since I've had the car less then a year, I've put almost a grand into it just to keep it running. I'm tired of putting money into it, and who knows how much its going to cost and who knows how long it till be before it freakin breaks down again. I'm throwing my hands up and walking away from it. I like gtp's but once they start to have problems might as well turn it in it seems like. I would love to own another gtp but one that is newer and not so many miles or problems.
    01 T/A WS6-SOLD
  10. #50 Re: i seriously need some help guys
    07 GT would be your ideal car then.
    Hope you have some cash ready though.
  11. #51 Re: i seriously need some help guys
    Nov 2010
    south east AZ
    Well after swapping the pcm and the knock module I hooked a fuel test kit to it and measured the psi at 40 key on, ideling, and steady rev. with the fpr vacuum disconnected it was about 50 psi. But while I was under the hood I was hearing a noticeable whisteling but I sprayed wd 40 every where that I could see and no difference in engine sound. But I do think it is a vacuum leak cuz when I hold the throttle open steady and increase lightly it gets louder to a point then stops, when I let off it comes back but like I said I'm having trouble pinpointing it. So a vacuum leak would explain why my fuel trims are all off, severe knock retard, bad mpgs. It seems to be somewhere around the back of engine or around the crossover pipe. When I twitch the throttle it also seems to hang for a second just above idle speed.
    Thoughts?
    01 T/A WS6-SOLD
  12. #52 Re: i seriously need some help guys
    checked EGR tube at the LIM?
    You have to unbolt it to check it.
  13. #53 Re: i seriously need some help guys
    Nov 2010
    south east AZ
    Egr deleted and blocked off, no leaks there either
    01 T/A WS6-SOLD
  1. It was fun guys
    By Louie3 in forum Off Topic Discussion
    Last Post: 01-12-2011, 11:43 AM
  2. Sup Guys
    By stock6 in forum Introductions/Noob Questions
    Last Post: 10-05-2010, 09:52 PM
  3. What do you guys think
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-11-2009, 07:11 AM
  4. Hello guys
    By EricGTP in forum Visual/Body Modifications
    Last Post: 04-29-2009, 02:40 AM
  5. attn: guys who are car salesman or guys who know them
    By shaferz in forum Off Topic Discussion
    Last Post: 03-25-2008, 05:05 PM
