Thread: Vacuum Leak?
Results 1 to 3 of 3
crock Vacuum Leak? 08-20-2011, 05:17 PM
Explicit_Spade Re: Vacuum Leak? 08-20-2011, 05:19 PM
crock Re: Vacuum Leak? 08-21-2011, 12:09 AM
  1. #1 Vacuum Leak?
    Donating Users crock's Avatar
    Traverse City, Michigan
    Im having trouble going up hills. When i gas it, the car doesnt wanna go. I have to put it into boost. Then i can go up the hill slowly. It didnt use to have this problem. On flat ground i can get up and go. The lim gasket was replaced last year. And most of the hoses were replaced recently.... Thanks for your opinions
    99 GTP- 104s, 180 Tstat, 1.9 rockers, 3.4, ls1 MAF, KN, 3''DP, HF cat, GMPP Strut Bars, Crappy Tune, Broken Tensioner Mod.
  2. #2 Re: Vacuum Leak?
    Omaha, NE
    Clean your MAF and Throttle body.
    If it continues, spray all gaskets and vac lines with the rest of the maf cleaner listening for a change in RPMs.
  3. #3 Re: Vacuum Leak?
    Hmm. Why didnt i thing about that? Thanks man. But does is sound like a vacuum leak?
  1. Vacuum Leak Help
    By RichardL12 in forum General Tech Discussion
    Last Post: 06-03-2010, 06:28 AM
  2. vacuum leak or bad egr
    By mjdennis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2010, 10:49 PM
  3. vacuum leak?
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2010, 01:27 PM
  4. vacuum leak
    By boredout in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-15-2008, 08:22 AM
  5. Bad vacuum leak
    By boredout in forum General Tech Discussion
    Last Post: 07-14-2008, 02:21 AM
