I have a 93 pontiac grand prix special edition and i need help
1.rear defrost won't work and fuse in fuse panel for the cluster is good
2.when the car starts it will rev high then idle down.
3.the will run good if the service engine soon light is on
4.anti lock brake light stays on
5.turn singles and haz lights can not be used for longer then a few secs of the column starts to smoke
6.needs a new power steering line (the one that comes off the pump that is bolted to the pump) have the new line no idea how to get it off the the pump
7.driver side door window track is bad
8.need driver side door handle
9.engine leaks anti freeze from a line that looks like it is under the battery(small leak)
10.the car also gets maybe between 10-15 mpg's last time i checked it was getting 12
i also try to run 93 oct gas in it
also any information i can get for this car would be great
