Thread: signal light switch question?
Results 1 to 3 of 3
  1. #1 signal light switch question?
    Jul 2011
    bristol,va
    does anyone know were the 2 pin connecter goes on the signal light switch? when i took my apart it was already unhooked, someone has already tried to fix it. i put a new switch in it and it can figure out were the 2 pin conn. goes, thanks anyone
  2. #2 Re: signal light switch question?
    Almost sounds like a soleniod for the key release. Do you have some pictures of the connector and area?
  3. #3 Re: signal light switch question?
    Jul 2011
    bristol,va
    I dont have any pictures at the moment, the two pin connector is coming out of the bottom of the signal light switch harness. there are two big harness`s that connect to a single one about a foot after they come out of the signal light switch
  1. signal light switch question?
    By hardrocrick in forum General Tech Discussion
    Last Post: 08-12-2011, 10:40 PM
  2. turn signal switch ???
    By bubba40 in forum General Tech Discussion
    Last Post: 07-23-2010, 12:30 PM
  3. Right signal light flashes fast, left signal flashes normal speed?
    By nboylie in forum General Tech Discussion
    Last Post: 11-23-2009, 06:38 PM
  4. turn signal switch
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 07-15-2009, 08:10 PM
  5. Need Instructions on signal light switch replacement
    By ragtops in forum General Tech Discussion
    Last Post: 03-22-2009, 05:44 PM
