Thread: LIM question
Results 1 to 5 of 5
Rivmage LIM question 08-14-2011, 10:10 PM
bps02gtp Re: LIM question 08-14-2011, 11:18 PM
Rivmage Re: LIM question 08-14-2011, 11:32 PM
BillBoost37 Re: LIM question 08-15-2011, 06:56 AM
Rivmage Re: LIM question 08-15-2011, 09:08 AM
  1. #1 LIM question
    Aug 2011
    Denver, Co
    So, I got my Grand Prix used with 140k+ miles. Is there any way to tell if the LIM has been done?
    Thank you,
    Scott
  2. #2 Re: LIM question
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    look around to see if you can see coolant leaking. just below the UIM or S/C whichever you have, there will be puddles of coolant sitting in the grooves of the LIM if you are having problems with a leak. if not and everything looks dry, you should be good to go. hopefully tho, at 140K it is done already.
  3. #3 Re: LIM question
    Aug 2011
    Denver, Co
    I've been checking the oil every couple days to check for coolant but, I haven't seen any yet. I have only had the car since Thursday night. I'm planning to do an oil change in the next couple of days. That should give me a better idea of the shape of the oil.
    Thank you,
    Scott
  4. #4 Re: LIM question
    Follow the bracket that holds the driverside uppoer motor mount to the engine. Look right where the valve cover meets the LIM at that bracket. Do you see a black gasket or aluminum?
    If you see an aluminum gasket, you are all set. If not, prep for an LIM gasket swap.
  5. #5 Re: LIM question
    Aug 2011
    Denver, Co
    Looks like its been done. One less thing for me to worry about.
  1. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  2. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  3. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
