Thread: easiest way to move battery to trunk?
Results 1 to 8 of 8
  1. #1 easiest way to move battery to trunk?
    Bunnell, FL
    bueller?
    I'm a Sex Offender
  2. #2 Re: easiest way to move battery to trunk?
    Pick it up, walk to the trunk and let go.
    If you could be more specific, I'm more than able to help ya.
  3. #3 Re: easiest way to move battery to trunk?
    Bunnell, FL
    what do i need to relocate the battery to trunk
    i.e. terminals connectors, best wires?
    I'm a Sex Offender
  4. #4 Re: easiest way to move battery to trunk?
    If I were doing it, I'd aim to knukonceptz and figure out what my budget was and go with the best cabling they offer in that budget.
  5. #5 Re: easiest way to move battery to trunk?
    you'd need a fused connection.
    a VERY solid ground.
    And ensure the wire is fairly large.
    make it easier to start.
    you'd want a battery box that you can vent externally.
    OR buy a nice expensive sealed battery.
  6. #6 Re: easiest way to move battery to trunk?
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    nothing wrong with a little hydrogen floating around in the cabin... it makes drives more entertaining.
    I would just but a kit online they seem over priced but when you price the wire and stuff yourself then you will see their not to bad
  7. #7 Re: easiest way to move battery to trunk?
    SE Level Member blown98gtp's Avatar
    Feb 2009
    iowa
    use welding cable, much cheaper.
    why do you want to put the battery in the trunk?
    98 gtp:L36/GenV/S1X/Pacesetters/FWI/Intense tune/timing commander/104s/P&P heads/DevilsOwn alky kit/ZEX dry shot/42.5#/shift kit/ScanGauge
  8. #8 Re: easiest way to move battery to trunk?
    Waukesha, WI
    im interested too, make room for IC resovoir?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  1. Best Motor easiest swap?
    By Rolling89GPSE in forum Engine
    Last Post: 01-06-2011, 12:34 AM
  2. which way is easiest?
    By daytonapacecarguy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2009, 08:09 PM
  3. run the power cable from battery to trunk - FINISHED!! PICS!
    By Freebeer187 in forum Audio, Security & Visual Electronics
    Last Post: 03-19-2009, 04:17 PM
  4. Easiest HP gains
    By mikes_comp_g in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2008, 02:17 AM
  5. easiest shift kit to install ?
    By bayareagtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-26-2008, 09:18 AM
