Thread: Driver infomation center bulb replacement questions
Results 1 to 14 of 14
  1. #1 Driver infomation center bulb replacement questions
    SE Level Member new2prix99's Avatar
    Jul 2011
    dwight,il
    On my 99 Gt the driver info center is so dim I can't read it. My question is can I change a bulb to make it brighter or is there another way to make it brighter. Any help would be greatly appreciated
  2. #2 Re: need help with info
    Charles City, IA
    There are a couple bulbs in it, there is a write up floating around on how to change them, I am going to move your thread to gen tech and rename it to get ya some more hits.
    SMGPFC Two Nipple General
  3. #3 Re: Driver infomation center bulb replacement questions
    Houston
    They are the same bulbs that are behind your instrument cluster. There are just 3 twist in bulbs. They are 194's
  4. #4 Re: Driver infomation center bulb replacement questions
    Jul 2011
    dwight,il
    OK thanks a lot ya if you can't tell I'm new to this page and new to the grand prixs
  5. #5 Re: Driver infomation center bulb replacement questions
    Charles City, IA
    No problem, we are here to help.
  6. #6 Re: Driver infomation center bulb replacement questions
    Jul 2011
    dwight,il
    Well I appreciate it greatly
  7. #7 Re: Driver infomation center bulb replacement questions
    Jul 2011
    dwight,il
    So all I have to do is pull the dash trim remove the (dic) and change the bulbs? I don't have to mess with trying to rewire anything?
  8. #8 Re: Driver infomation center bulb replacement questions
    Charles City, IA
    dont belive so I have mine sitting on the bench and can look tomorrow if I remember
  9. #9 Re: Driver infomation center bulb replacement questions
    read through this and you should find your answer. http://www.grandprixforums.net/addin...3-gp-8171.html
    Snorlax strikes again.
  10. #10 Re: Driver infomation center bulb replacement questions
    Jul 2011
    dwight,il
    Ya I read that one already but nothing says if its bulbs or all internal lighting. The car is completely stock except the $300 CD player but no wires were snipped or anything so if it IS bulbs that would be great
  11. #11 Re: Driver infomation center bulb replacement questions
    Houston
    Quote Originally Posted by new2prix99 View Post
    Yep..just pull off the dash bezel, the DIC is just held in by two push in clips, one on the left side and one on the right side. Remove the harness on the back of it. Then you need to take the cover off of the DIC. Its just got some prongs that hold it there. You'll see the little square cutouts on the outer cover. Take a little screw drive or whatever you can find and push those plastic prongs down, gently. When you remove the cover you'll see this.....
    The three bulbs on the right are the ones you'll need to replace (one of the bulbs in this pic is already missing). No wiring needed, no tools needed (except to push down the prongs on the cover)
  12. #12 Re: Driver infomation center bulb replacement questions
    Yoga city
    While your at it use LEDs and change the color if you wish. If you can solider it's a snap
  13. #13 Re: Driver infomation center bulb replacement questions
    Jul 2011
    dwight,il
    Ah I kinda like the red makes me feel like I'm flying when I'm passing everyone LOL and thanks Keith I think I can manage that lol
  14. #14 Re: Driver infomation center bulb replacement questions
    Dec 2008
    Lawndale, CA
  1. Dim Driver Information Center
    By ljmonnin12 in forum General Tech Discussion
    Last Post: 02-13-2012, 09:25 PM
  2. driver information center
    By bc1 in forum General Tech Discussion
    Last Post: 12-12-2010, 10:21 AM
  3. Driver Information Center
    By techn9cian99GTP in forum Audio, Security & Visual Electronics
    Last Post: 12-12-2010, 10:02 AM
  4. Changing Bulb in DIC, Driver Information Center
    By MRinthePROgress in forum Engine
    Last Post: 04-18-2010, 09:43 PM
