Yep..just pull off the dash bezel, the DIC is just held in by two push in clips, one on the left side and one on the right side. Remove the harness on the back of it. Then you need to take the cover off of the DIC. Its just got some prongs that hold it there. You'll see the little square cutouts on the outer cover. Take a little screw drive or whatever you can find and push those plastic prongs down, gently. When you remove the cover you'll see this.....
The three bulbs on the right are the ones you'll need to replace (one of the bulbs in this pic is already missing). No wiring needed, no tools needed (except to push down the prongs on the cover)
