Thread: Windshield wiper fluid not working
Results 1 to 14 of 14
  1. #1 Windshield wiper fluid not working
    Jersey
    Whats up gp heads. I have a problem with my 97 gp se. When i turn the key to the on position the low fluid light doesnt come on. Besides that, the wiper works fine but there"s no fluid coming out. The fluid is basically full!! The wiper hoses are fine as well. I wanted to know what can be the problem? Is it the pump or something?... im not sure. Could use the help, thanks
  2. #2 Re: Windshield wiper fluid!!!!!
    the little fluid pump its prolly dead, buy a new one and or make sure a fuse aint blown.
  3. #3 Re: Windshield wiper fluid!!!!!
    probably the pump i think i have one laying around if your interested
  4. #4 Re: Windshield wiper fluid!!!!!
    Jersey
    Ok kool! Do you by chance know which fuse controls that??
  5. #5 Re: Windshield wiper fluid not working
    Charles City, IA
    Check all the fuses
    SMGPFC Two Nipple General
  6. #6 Re: Windshield wiper fluid!!!!!
    Jun 2011
    Detroit, MI
    Quote Originally Posted by ajoliver2010 View Post
    You have a fuse chart in the lid of your fusebox under the hood it should say which one it is there.
    iLoveSpade
  7. #7 Re: Windshield wiper fluid not working
    Jul 2010
    Coquitlam,BC,Canada
    If you need to, here is how to change the washer pump.
    If you are a contortionist, you might be able to get at it from above; fat hands here was unable to pull it off.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #8 Re: Windshield wiper fluid not working
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Hi newbie here, just bought a 1997 GTP
    No washer spray, wipers work.
    Resorvoir is on top battery type. There is a hose hanging loose from the tank.
    The one to the nozzles is connected. Is the thing in the tank the pump or low level sensor ? I think the previous owner lost the pump ? Does it mount in the engine .
    Thanks
  9. #9 Re: Windshield wiper fluid not working
    Topeka, KS
    The pump mounts at the bottom of the tank. You can get to it by undoing the inner fender well on the passengers side. If you have a hose hanging loose welp there's your problem.
  10. #10 Re: Windshield wiper fluid not working
    PA
    Quote Originally Posted by rynoman03 View Post
    He has a 97 and said it is on top the battery.
    If you didn't have a pump, you wouldn't be able to put fluid in the reservoir or it would run right out. The pump presses into the reservoir down towards the bottom of it. It has a plug going into it and a hose coming out of it that goes to the washers. There is a hose coming out of the top of the reservoir that just hangs down. I guess it is an overflow. Not really sure what that was ever for. The low washer fluid sensor is on the top over by the fender brace. It has a wire plug going to it.
    2001 GSE
  11. #11 Re: Windshield wiper fluid not working
    Most likely you need a new pump. I'm pretty sure I have a good one laying around if your interested pm me
  12. #12 Re: Windshield wiper fluid not working
    GTP Level Member
    Oct 2011
    Raleigh, NC
    fixed, hoses were routed wrong, and pump was missing, previous owner had a hose stuck in were the pump goes. Also had the line from the jets hooked to the overflow nozzle on top of the reservoir. thanks for the help,
    1997 Red GTP 182000 miles stock
  13. #13 Re: Windshield wiper fluid not working
    so do you need a pump?
  14. #14 Re: Windshield wiper fluid not working
    GTP Level Member
    Oct 2011
    Raleigh, NC
    no , sorry, picked one up locally. thanks anyways
  1. windshield wiper
    By backinblackgtp in forum General Tech Discussion
    Last Post: 12-30-2011, 11:58 PM
  2. Driver's Side Windshield Wiper Stopped Working.
    By Chaotic94 in forum General Tech Discussion
    Last Post: 02-27-2011, 05:29 PM
  3. Windshield Wiper Help
    By Liquifire in forum General Tech Discussion
    Last Post: 01-17-2010, 03:19 PM
  4. Windshield Wiper Issue..
    By EarlyGTDriver in forum General Tech Discussion
    Last Post: 08-26-2009, 05:00 PM
  5. windshield wiper help
    By maybe_memories in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2008, 02:48 PM
