Quote Originally Posted by rynoman03 View Post
The pump mounts at the bottom of the tank. You can get to it by undoing the inner fender well on the passengers side. If you have a hose hanging loose welp there's your problem.
He has a 97 and said it is on top the battery.
If you didn't have a pump, you wouldn't be able to put fluid in the reservoir or it would run right out. The pump presses into the reservoir down towards the bottom of it. It has a plug going into it and a hose coming out of it that goes to the washers. There is a hose coming out of the top of the reservoir that just hangs down. I guess it is an overflow. Not really sure what that was ever for. The low washer fluid sensor is on the top over by the fender brace. It has a wire plug going to it.
