Thread: More boost?
Results 1 to 20 of 22
  1. #1 More boost?
    Donating Users
    W-S, NC
    Just ported and polished my front exhaust manifold, and noticed that the boost gauge at full throttle is showing 7psi. Anyone explain this? Car feels stronger in mid and upper RPM's.
  2. #2 Re: More boost?
    Feb 2008
    What were you getting before the P&P? Someone correct me if I'm wrong but I understand that as you open things up, boost pressure drops due to more efficient processing of air. I saw a slight drop when I had my 3" DP installed and another slight one when I did the P-Log. I was at 12-13 before, and now get 11-12 max.
    Oh and it will feel a bit stronger up top. More so with more flow mods
  3. #3 Re: More boost?
    Donating Users
    W-S, NC
    Stock pulley 6psi....
  4. #4 Re: More boost?
    TDCRacing
    Guest
    Quote Originally Posted by Boger's99GTP View Post
    6 psi?
  5. #5 Re: More boost?
    Bastard Reptile's Avatar
    Kansas City, MO
    Quote Originally Posted by DanGTP View Post
    You are correct! When you lessen the restriction on the intake and exhaust sides, you make the engine more efficient. Meaning you're scavaging the exhaust gases much easier than you were before. You're probably about ready for some more goodies now with a tune tweak.
  6. #6 Re: More boost?
    Kansas City, MO
    That's about right with what he may have done to it.
  7. #7 Re: More boost?
    TDCRacing
    Guest
    He said 7psi at first then he said the stock pulley gives him 6psi. You are wrong. Get back to work!
  8. #8 Re: More boost?
    Kansas City, MO
    Don't argue with me!
    ok, maybe you should argue with me....for some reason I was thinking he showed a drop in boost.....
    More coffee Brian.....more coffee.
  9. #9 Re: More boost?
    TDCRacing
    Guest
    Quote Originally Posted by Reptile View Post
    YES SIR.
  10. #10 Re: More boost?
    Apr 2008
    Chillin at the Beach , VA
    Could it be that sense his exhaust is flowing out better, his engine is hitting the rpm's quicker pulling in more air to create the extra boost??? Don't really know, just trying to throw some ideas out there and learn about the system more.
  11. #11 Re: More boost?
    TDCRacing
    Guest
    Quote Originally Posted by BADAZGTP View Post
    Well, he is actually loosing boost due to the fact that his exhaust is more free flowing wich means less back pressure.
  12. #12 Re: More boost?
    Apr 2008
    Alright, I can see that.
  13. #13 Re: More boost?
    Donating Users
    W-S, NC
    Maybe I got a ghetto gauge..lmao The stock pulley is normally 6 psi and has peaked to 7psi before, so i dont know whats going on. The car does feel stronger tho.
  14. #14 Re: More boost?
    Donating Users
    W-S, NC
    im guessing the boost will drop more with a u-bend delete. With the decrease in boost, is off the line acceleration going to suffer since the powerband should shift into higher RPMs? Im just trying to keep my 60' times close or better than they are now @ 2.02
  15. #15 Re: More boost?
    TDCRacing
    Guest
    You shouldnt notice a change in psi with just a u-bend deleate.
  16. #16 Re: More boost?
    Donating Users blowfishRus6's Avatar
    g.a.
    damn your 60' times....im still jelious :/
    and i aint got an answer to your question
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  17. #17 Re: More boost?
    g.a.
    isent the stock stall around 3000 tho. so you should still be in mid range power off the line... i would think
    its slow.
  18. #18 Re: More boost?
    Donating Users
    W-S, NC
    Yes but remember that you'll spin like crazy unless you have some sticky tires. Hince the reason i stall 1800 to 2200'ish Rpm's or so.
  19. #19 Re: More boost?
    g.a.
    yea but the stall converter. if you hit it around 1500 or so it jumps up to 3000...
    its slow.
  20. #20 Re: More boost?
    Donating Users
    W-S, NC
    Yeah... I see what your saying now.
  1. Boost Bypass mod
    By BADAZGTP in forum General Tech Discussion
    Last Post: 05-30-2008, 11:49 AM
  2. Boost Bypass Mod????
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2008, 11:04 AM
  3. XP cam boost and vac numbers
    By 1998gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2008, 10:54 PM
  4. what limits boost
    By deangtp in forum PCM Tuning
    Last Post: 04-08-2008, 03:53 PM
  5. Stock L36 + Boost =
    By Sinister Performance in forum General Tech Discussion
    Last Post: 02-22-2008, 11:28 PM
