Thread: Water in the floorboard question
Results 1 to 3 of 3
  1. #1 Water in the floorboard question
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    The question is not about my car. I've taken care of my car already and it works great now. I was wondering if anyone knew if the same piece to fix the problem would work on a 03 Buick Rendezvous? I realize they are bigger cars and all but figured I'd ask. If not is there a similar piece that does the same thing?
  2. #2 Re: Water in the floarboard question
    have you had a chance to look at the part on the Rendezvous? is it the same bad set up as the gp or regal?
    if so i took a thick plastic bag cut it and tucked it under the lip where the original flap is tucked in, folded it to the other side and caulked both sides at the top with a thin bead of caulk just to hold it in place, mines been like this for a year now and still dont leak.
    ideally some kind of peel and stick rubber would work too, or some old rubber tube and rubber cement would work as well, just gluing a patch on the old flap, if you know what i mean.
  3. #3 Re: Water in the floorboard question
    Bunnell, FL
    close the sunroof
    I'm a Sex Offender
  1. water on passeger floor question
    By Jakegday in forum General Tech Discussion
    Last Post: 11-16-2010, 02:26 PM
  2. Water Pump Installation Question
    By Lawngoose in forum General Tech Discussion
    Last Post: 12-07-2009, 09:52 PM
  3. Silly Question: How does water stay out of ANY intake?
    By nickbuol in forum General Tech Discussion
    Last Post: 08-17-2009, 02:29 PM
  4. Quick question (water pump)
    By cgator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 08:03 AM
  5. Quick question (water pump)
    By cgator in forum General Tech Discussion
    Last Post: 09-21-2008, 10:13 PM
