Thread: 97 Grand Prix GT "check tire pressure" light on
Results 1 to 5 of 5
  1. #1 97 Grand Prix GT "check tire pressure" light on
    Tucson, AZ
    Where is the sensor that measures tire pressure? I've searched and it almost seems as if the tire pressure indicator is built into the hub? This just sounds strange, as my simple mind doesn't understand how the hub sensor can detect low tire pressure.
    For the record, the "Parking Brake" and "Trac Off" lights are also on. I'm thinking they all have to do with faulty hubs, or sensors built into the hubs. Plausible? Thanks, all.
  2. #2 Re: 97 Grand Prix GT "check tire pressure" light on
    Charles City, IA
    It is based off wheel speed. When one is reading faster than the rest it thinks its low. Sounds like you have a bad hub get the codes scanned.
    SMGPFC Two Nipple General
  3. #3 Re: 97 Grand Prix GT "check tire pressure" light on
    Tucson, AZ
    Thanks for the quick reply. Would those type of codes be scanned through the OBD port?
  4. #4 Re: 97 Grand Prix GT "check tire pressure" light on
    Charles City, IA
    yeah you need a scanner that will do abs tho.
  5. #5 Re: 97 Grand Prix GT "check tire pressure" light on
    97's have tps??...
    SMGPFC Member #10
  1. ABS and check tire pressure light on
    By GTP2188 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2010, 02:12 PM
  2. ABS and check tire pressure light on
    By GTP2188 in forum Brakes/Suspension/Chassis
    Last Post: 11-15-2010, 07:00 PM
  3. "half" light tinting expiriment. looks cool. check it out.
    By colindunn in forum Visual/Body Modifications
    Last Post: 06-30-2010, 08:18 AM
  4. "CHECK GAGES" And Battery Light?
    By K7Gixxer750 in forum General Tech Discussion
    Last Post: 11-22-2009, 04:16 AM
  5. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
