Thread: boost gauge doesnt go all the way up
Results 1 to 6 of 6
  1. #1 boost gauge doesnt go all the way up
    Aug 2011
    port huron
    Just replaced my blown motor with a used one from rpm auto and everythings hooked up but my boost gauge won't go all the way up even at WOT, the old motor and supercharger made the gauge go up easily, its completly stock, 98 gtp...anyone know what it could be ?
  2. #2 Re: boost gauge doesnt go all the way up
    recheck all vacuum lines.
    follow the line around the supercharger to the map sensor. look at all the T's and elbow for cracks in the rubber.
  3. #3 Re: boost gauge doesnt go all the way up
    Aug 2011
    port huron
    There was this weird looking peice I replaced thinking that would be it but still nothing. I've looked over and over each line , there's no cracks or anything.
  4. #4 clunking noise when hit gas and let go
    Aug 2011
    port huron
    It only happens once in a while but it makes a clunking noise sometimes shifting into 4th and when I let go of the gas then hit it fast again. I would like to no what this is. I know I need outter tie rods but I don't think that would do that.
  5. #5 Re: boost gauge doesnt go all the way up
    You don't get a thread for each problem if they're all happening at the same time.
    Moved this to the proper section.
    Introductions is for introductions.
  6. #6 Re: boost gauge doesnt go all the way up
    Aug 2011
    port huron
    Would a 99 gtp transmission fit in my 98 gtp.?
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
