Thread: Smoke upon (cold) hard acceleration...
Results 1 to 14 of 14
  1. #1 Re: Smoke upon (cold) hard acceleration...
    SE Level Member HEVEYMETIL's Avatar
    Western New York
    I use less than a quart at every change - I just want to make sure it's "acceptable" lol - apparently GM says so - thanks for that, Bill. (I googled and saw some crazy oil consumption guidelines!)
    I know the manual says use only 5W30, but would a heavier weight be acceptable? (esp in this HOT weather). I always use Mobil 1 - and my school of thought was always increase weight with mileage, to a certain extent.
    Bill - I'm still learning - I understand what predetonation is, but can you explain how it negatively affects the engine?
    Thanks again, guys.
  2. #2 Re: Smoke upon (cold) hard acceleration...
    Sure..
    Being supercharged your engine is being force fed air via the charger. The programming in the pcm is looking at the boost pressure and fueling accordingly. However since our cars are shipped all over the world to many climates etc. they are generally programmed. Then there's other systems put in place to try and ensure that if low octane fuel, high humidy, hot temps, odd stuff is present that they engine should run and run decently w/o blowing up. This is where hte knock sensors come in. They measure the amount of noise in the engine block. When the level hits a certain amount or noise happens when the pcm doesn't expect it.. the pcm has the programming to retard the timing. This takes away power and helps stop the dectonation issue from happening. This is also part of the system that tells us which cylinder is misfiring. Pretty cool that a sensor can hear and the pcm can interpret which cylinder an issue is happening on.
  1. Engine stuttering on hard acceleration
    By zeppelinrocks18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2011, 07:09 PM
  2. Shuttering on hard acceleration
    By Pshnmeawy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2011, 01:52 PM
  3. cold start smoke
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2009, 09:42 PM
  4. 2000 GTP miss on hard acceleration
    By gtp2000 in forum Introductions/Noob Questions
    Last Post: 07-26-2009, 01:06 PM
  5. Replies: 6
    Last Post: 10-11-2008, 09:30 PM
