Thread: Throttle body intake questions
Results 1 to 7 of 7
  1. #1 Throttle body intake questions
    SE Level Member Dobbs122's Avatar
    Shelby Ohio
    wanting to get a ls1 TB but read here they dont just bolt up whats a good alternative or can i buy a ls1 TB off a junkyard and find the extra parts online? im doing away with my FWI it was not done right by the last owner and going for a open cone when i get a new tb thanks for the help !
  2. #2 Re: Throttle body intake questions
    Feb 2008
    What mods does the car have done to it? There aren't any TB's off other engines that will just bolt right up. You'll have to buy an adapter plate to make the conversion. ZZP sells an adapter plate for a Northstar TB, which is the same diameter as the LS1, but probably easier and cheaper to find. Just make sure you get one from a 2000+ year with 3 mounting bolts and not 4.
  3. #3 Re: Throttle body intake questions
    Shelby Ohio
    Quote Originally Posted by DanGTP View Post
    Not alot of mods high flow cat u-bend delete fwi just waiting for tax season to do the 3.4 pully mod with supporting mods just getting cheap mods for now and is the adapter plate sold on its own ?
  4. #4 Re: Throttle body intake questions
    TB should be put on the back burner till you invest in an intercooler or a cam.
  5. #5 Re: Throttle body intake questions
    Omaha, NE
    I'm with Matt, there's no point in wasting money on mods that won't benefit you right now.
    A throttle body is something you don't need until you're outflowing stock.
  6. #6 Re: Throttle body intake questions
    Feb 2008
    I agree with the other two. For what you have, I'd say scrap the TB idea and go for a set of headers.
  7. #7 Re: Throttle body intake questions
    LS1 TB Setup wouldn't be cheap.
    You'd need an adapter plate for one, an external LQ4/LS1/SLP 85mm MAF Sensor, LS1 TPS/IAC, You'd need to cut off the throttle bracket, flip it over...and weld it on backwards..then in order for it to be efficient enough, it would need to be tuned for it, along with the blower being port matched on the inlet side to benefit fully from it. On a stock pulley...it would probably go more harm than good...you wouldn't need a LS1 TB setup until sub 3.25" pulley sizes...full size intercooler or cam...
  1. n* and ls1 throttle body questions
    By 99GPGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2011, 06:04 PM
  2. N* throttle body
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2009, 01:41 PM
