Thread: no #1 speed on hvac?
Results 1 to 9 of 9
  1. #1 no #1 speed on hvac?
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    so today my number one speed on my hvac quit. there is no air flow at all when it is on the "max ac dash vents" and very very low flow when on the "regular dash vents". All the other speeds (2-5) work fine and doesnt make a differece if a/c is on or off, or if the heater is on. Also the a/c compressor does kick in when i switch it on the to the number one level
    I did some searching and couldnt come up with anything on here. anyone got a link or know what i could try to fix it?
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
  2. #2 Re: no #1 speed on hvac?
    Feb 2008
    I would suspect your blower motor resistor is bad. They're fairly inexpensive at your local parts store.
  3. #3 Re: no #1 speed on hvac?
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    yep exactly it just the resistor! had the problem and had it fixed by the dealer only 25$ with labour lol
  4. #4 Re: no #1 speed on hvac?
    Apr 2011
    Fargo
    Quote Originally Posted by RyanL View Post
    That's it! Thats just how much they are At oriellys. Was it a gm dealer?
  5. #5 Re: no #1 speed on hvac?
    Ya fm just down the road from my house it took them less than 10 mins to do it!
  6. #6 Re: no #1 speed on hvac?
    SE Level Member jmt455's Avatar
    SE Michigan
    It's probably the resistor, but this problem is also a symptom of a failing ignition switch.
    83 Bonneville wagon
    08 G8 Base
  7. #7 Re: no #1 speed on hvac?
    Apr 2011
    Fargo
    It was a resistor if anyone cares for future reference
  8. #8 Re: no #1 speed on hvac?
    all these post and nobody said that?
    SMGPFC Member #10
  9. #9 Re: no #1 speed on hvac?
    Apr 2011
    Fargo
    Well thanks bro. I just wanted to let people know the correct answer for future reference.
  1. Will Dual HVAC Work in Stock HVAC
    By ljmonnin12 in forum General Tech Discussion
    Last Post: 11-25-2010, 10:57 PM
  2. Replies: 25
    Last Post: 09-01-2010, 05:49 AM
  3. HVAC Fan Speed Setting 5 will not work
    By nrengle in forum General Tech Discussion
    Last Post: 01-22-2010, 03:43 PM
  4. 04 hvac
    By Scott Francis in forum Introductions/Noob Questions
    Last Post: 10-16-2009, 03:36 PM
  5. HVAC doesnt blow air any speed
    By GTX in forum General Tech Discussion
    Last Post: 01-01-2009, 01:11 AM
