Thread: Disabling Autolock
Results 1 to 7 of 7
  1. #1 Disabling Autolock
    Sep 2011
    GTA, Ontario
    Sorry if this is in the wrong forum. I have a '94 SE 3.1. The owners manual says to take out fuse #7 to disable it. I did this and nothing happened, so I put it back.
    Any way to turn off this annoying feature?
    I did the search on this topic but was not able to find it.
    Thanks
  2. #2 Re: Disabling Autolock
    Sep 2011
    GTA, Ontario
    No takers on this PITA feature?
    Thanks
  3. #3 Re: Disabling Autolock
    Jun 2011
    Detroit, MI
    Check the manual.
    iLoveSpade
  4. #4 Re: Disabling Autolock
    St. Louis
    [QUOTEThe owners manual says to take out fuse #7 to disable it.][/QUOTE]
    Looks like he did, unless there is another fuse that controls this feature. Might be time for Google on this one.
  5. #5 Re: Disabling Autolock
    Jun 2011
    Detroit, MI
    THere should be something more about programming that stuff, not fuse, but idk about that gen gp
    iLoveSpade
  6. #6 Re: Disabling Autolock
    Ocala, FL
    With the 97-03 its in the manual.. You enter programming mode and then click the locks til you hear the right number of chimes.
  7. #7 Re: Disabling Autolock
    Sep 2011
    GTA, Ontario
    I don't see a programming mode in the '94 manual. I asked the local independent garage when fixing the wheel alignment, and the guy said it was complicated, but not sure if that was his take on my abilities or for the shop to do it. So thought I would try here.
    Thanks will see what the Google net hauls in.
  1. Disabling DRL's in a 04+
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 12-03-2011, 01:17 PM
  2. Completely Disabling ABS?
    By SuperSport in forum Brakes/Suspension/Chassis
    Last Post: 06-28-2009, 12:03 AM
  3. Delayed Locking and AutoLock Problem
    By kmoran09 in forum General Tech Discussion
    Last Post: 06-01-2009, 12:26 PM
  4. disabling DRL's?
    By TJs97 in forum General Tech Discussion
    Last Post: 09-10-2008, 11:18 PM
  5. 98 Grand Prix GT programming autolock feature??
    By Fritcr in forum General Tech Discussion
    Last Post: 04-29-2008, 07:34 AM
