Thread: supercharger starting to go
Results 1 to 20 of 22
  1. #1 supercharger starting to go
    Jul 2010
    St. Charles Il
    I dont know if Im posting this is right spot forgive me if Im not. My supercharger is starting to make noise really gets loud after 2200 rpms. MY mech said its starting to go. Now my car has 185000 miles on original engine/trans. Does leak some oil. Now my question is this should I replace this supercharger. Ive been told replacing it with a motor with this miles can blow my engine. What do you all think???
  2. #2 Re: supercharger starting to go
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    Quote Originally Posted by JAG72 View Post
    my advice is to check ya coupler.. it could make the sc make noise..
    i was told you shouldnt be able to turn it or it shouldnt have a lot of play in it.. im sure one of these guys will correct me if im wrong
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  3. #3 Re: supercharger starting to go
    Does it sound like rocks rattling around inside the supercharger?
    Take off the charger belt and see if there is any play when you turn the pulley, does it move at all before you feel the rotors start to turn?
    Can you take a vid of the noise and put it up for us to hear.
    I highly doubt replacing the supercharger on your engine will cause it blow up, do not believe everything a mechanic tells you.
  4. #4 Re: supercharger starting to go
    Grand Rapids, MI
    yeah im willing to bet it's the coupler, that's the most common failure point/noise maker inside the supercharger. it is possible that the bearings inside the blower are bad, which would require a new supercharger, but my money is on the coupler.
    furthermore, putting on a new supercharger will not by any means blow up your engine. someone didn't have their wheaties on that one...
  5. #5 Re: supercharger starting to go
    Jul 2010
    St. Charles Il
    Its a "loud" whiring sound that gets louder as rpms climb not a grinding type noise. a whirring type sound at 65 and up you can really hear it. i dont know how to post a video or anything BUT THANKS FOR STICKING WITH ME HERE!!!!!
  6. #6 Re: supercharger starting to go
    when i bought my regal i took it to a shop and had them go over it real fast, my s/c coulper was making a real racket, and the mechanic said the sc was shot, and i would need a new one, i had already heard the car run before i took it to a shop with the sales man the day before i found this site and found my problem was the coupler, so i bought the car, letting the sales man think i need a 500 dollar part along with everything else it needed, 50 bucks later it runs so smooth now, and its so a diy thing. it took about 45 minutes as this was my first time going at it.
    i got my coupler off ebay for 20 bucks and used gm sc oil.
  7. #7 Re: supercharger starting to go
    do you have a stock air box and filter on the car still?
  8. #8 Re: supercharger starting to go
    Grand Rapids, MI
    yeah, it could be the coupler. but you say it sounds like a whirring noise. superchargers do to tend to whine but usually at high RPMs, and usually not audible with stock box.
    a video would reallyyyyy help
  9. #9 Re: supercharger starting to go
    brunswick
    if you get the video to your computer just go to youtube and upload it (assuming you have a youtube account) then just post the link in this
  10. #10 Re: supercharger starting to go
    Mine makes a load whiring noise at idle but I have an open cone intake.
  11. #11 Re: supercharger starting to go
    Grand Rapids, MI
    or photobucket is fine for uploading videos as well
  12. #12 Re: supercharger starting to go
    Jul 2010
    St. Charles Il
    everything is stock on the car
  13. #13 Re: supercharger starting to go
    brunswick
    mine is loud on my car.. i also has a open cone home made intake..
  14. #14 Re: supercharger starting to go
    Jul 2010
    St. Charles Il
    It didnt whime like this a year ago when I got the car. My brother gave me the car and he NEVER abused it I think thats why its so solid with this many miles. You can really hear the noise at highway speeds
  15. #15 Re: supercharger starting to go
    Grand Rapids, MI
    you'd have to make a video of the whine. GPs will run forever if maintained lol
  16. #16 Re: supercharger starting to go
    brunswick
    only thing i say is try to post a video...... or look on youtube and find one similar to yours
  17. #17 Re: supercharger starting to go
    GT Level Member 99GPGTP's Avatar
    Rome GA
    take the belt off and just see if there is any play in the coupler, if so just replace it and see if the noise is gone.
    99gtp 3.4"on ported m90, zzp 1.0 pcm, speeddaddy headers, stock mufflers w/cat and res delete,104's,FWI,180* stat, exhaust ported heads,Dog bones flipped, 18" 350z wheels
  18. #18 Re: supercharger starting to go
    Jul 2010
    St. Charles Il
    I will look into posting a video for you guys and that coupler
  19. #19 Re: supercharger starting to go
    The Boss Iceman6669's Avatar
    Jun 2011
    Did you recently do plugs or wires? The reason I ask is because the other day I was messing around under the hood of my car and had the "cover" thing off. I put it back on and went for a good long road trip. Almost instantly I heard a BAD whining noise. I was worried it was something serious. The car still ran great just S/C was loud. I got it home and figured out that I had pinched some plug wires under the lip of the cover and it had not "seated" right. I fixed it and the noise went away.
  20. #20 Re: supercharger starting to go
    Jul 2010
    St. Charles Il
    I havent done anything under there yet, im going to do new plugs/wires soon
  1. Starting to mod my GXP - help me.
    By extreme in forum 5.3L V8 (LS4)
    Last Post: 09-11-2011, 10:28 AM
  2. 97 gtp not starting
    By billysmth555 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2011, 02:04 PM
  3. Just Starting!
    By fpgt17 in forum Introductions/Noob Questions
    Last Post: 01-17-2011, 01:01 PM
  4. Supercharger coupling OR Supercharger belt tensioner?
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 07-23-2010, 11:56 AM
  5. Will a 2001 Bonneville supercharger work on a 97 gtp?supercharger swap
    By Bunique7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2010, 08:39 PM
