Thread: speed governor
Results 1 to 20 of 38
  1. #1 Re: speed governor
    I live here. TLSheff's Avatar
    Or in some rare cases you get this
  2. #2 Re: speed governor
    GT Level Member RegalGS98s's Avatar
    NJ
    Damn, I just saw this on TV about a week ago. They didn't even use the same model of car when doing the original test. Me and my friend still think the tire and guardrail played a major factor. If they really were trying to do a solid test, they would use something with the same amount of cushion as grass and then have the solid drain. Instead, they just used some ramps.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  3. #3 Re: speed governor
    Quote Originally Posted by RegalGS98s View Post
    Your mistaken friend. That was a young kid running and the cam was a cop that happened to be in the right area. He walked away but yea... no ramp, he hit the police turn around thats gravel and ramped off of it and hit the center support. Car split into three pieces and he was lucky to survive. Just fitting given the conversation.
    Police camera captures 100mph car crash in Ohio - Telegraph
  4. #4 Re: speed governor
    NJ
    There's isn't a turn around there, there's a guardrail, grass and a storm drain. The ramp was in the re-enactment test the the crash investigator was trying to perform. The first test it looked like a BMW they were using instead. The front is shaped completely different from a Trans Am. Yeah, that guy was definitely lucky.
  1. Top Speed Governor/Limitor
    By udmercy35 in forum General Tech Discussion
    Last Post: 02-07-2011, 09:18 AM
  2. Top speed WITH GOVERNOR?
    By 05PontiacGP in forum General Tech Discussion
    Last Post: 10-16-2010, 09:36 AM
  3. rev governor
    By Sabzz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-04-2010, 07:31 PM
  4. Replies: 25
    Last Post: 09-01-2010, 05:49 AM
  5. Top Speed of GTP
    By robahr24 in forum General Tech Discussion
    Last Post: 08-21-2008, 03:00 PM
