Thread: Whining From Supercharger
Results 1 to 11 of 11
  1. #1 Whining From Supercharger
    El Cajon
    Im getting a low to high pitch whine coming from my Supercharger as I accellerate and its getting worse. I have a 1998 Pontiac Grand Prix GTP. This started about a week ago and I just changed the coupler in the Snout and I used GM Supercharger Oil about the same time. I think it might be the Rotor bearings going bad but Im not sure. Any answer as to what this could be will be greatly appreciated. A friend of mine said that when I changed the oil I cleaned out what was keeping the bearings from failing, but the bearing problem would have showed up anyway. I have 137,000 miles on the engine and I keep the fluids top off and changed regularly. No leaks at all.
  2. #2 Re: Wining From Supercharger
    ‪04 Kenne Bell Cobra fly-bys / wot passes (643rwhp/613rwtq)‬‏ - YouTube
    Like at 35 seconds?
    If not.... how do you know its not one of your accessories failing?
  3. #3 Re: Wining From Supercharger
    Texas
    Quote Originally Posted by Grand Prix1 View Post
    Im getting a low to high pitch wine coming from my Supercharger as I accellerate and its getting worse. I have a 1998 Pontiac Grand Prix GTP. This started about a week ago and I just changed the coupler in the Snout and I used GM Supercharger Oil about the same time. I think it might be the Rotor bearings going bad but Im not sure. Any answer as to what this could be will be greatly appreciated. A friend of mine said that when I changed the oil I cleaned out what was keeping the bearings from failing, but the bearing problem would have showed up anyway. I have 137,000 miles on the engine and I keep the fluids top off and changed regularly. No leaks at all.
    Yep it's the bearings, mine did the same. If you want to isolate it completly to the S/C then just take off the belt and drive it. See if it's making the same noise. But chances are it is the bearings.
    85 Corvette
    01 TA
    03 Z06
  4. #4 Re: Wining From Supercharger
    I live here. TLSheff's Avatar
    Simple check is pull the belts and roll the pulleys, every pulley except the balancer should roll smoothly, if it grinds, hesitates, or has a rough spot it needs to be replaced.
    Just a check before you go thru the hassle to replace the SC bearing to find out its still there and it was just a $5.00 idler pulley
  5. #5 Re: Wining From Supercharger
    El Cajon
    I removed the belt to the Supercharger and the noise went away. Does anyone know where I can purchase a good used or remanufactured SC or instructions on how to remove and rebulid the supercharger I have already.Any help would be greatly appreciated. I call Eaton and they sent me to Magnusson Superchargers. They completely replace everything but the housing but they want $1100 for the one they rebuild and to me that's a bit to much.
  6. #6 Re: Wining From Supercharger
    Superchargers are supposed to whine...wth
  7. #7 Re: Wining From Supercharger
    El Cajon
    My supercharger has never made this type of noise and as I stated when I removed the SC belt the loud noise/wine has stopped.
  8. #8 Re: Wining From Supercharger
    Can we get a video?
    Makes for a much easier diagnoses process.
  9. #9 Re: Wining From Supercharger
    Out West
    Winning!
  10. #10 Re: Whining From Supercharger
    I fixed it for you...
  11. #11 Re: Whining From Supercharger
    Out West
    Buzzzzzkill! D:
  1. Supercharger coupling OR Supercharger belt tensioner?
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 07-23-2010, 11:56 AM
  2. Will a 2001 Bonneville supercharger work on a 97 gtp?supercharger swap
    By Bunique7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2010, 08:39 PM
  3. Supercharger
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 06:24 PM
