Thread: 3.5-2.9 drop...OMFG!!!!
Results 21 to 40 of 41
  1. #21 Re: 3.5-2.9 drop...OMFG!!!!
    you need more injectors, you shouldnt be retarding any timing. you want to have the timing as high as it can go befor it start to retard some for the knock your creating.
  2. #22 Re: 3.5-2.9 drop...OMFG!!!!
    Either you're kidding.
    Or you're kidding.
    I hope.
  3. #23 Re: 3.5-2.9 drop...OMFG!!!!
    im kidding
  4. #24 Re: 3.5-2.9 drop...OMFG!!!!
    GTP Level Member AjL227's Avatar
    IL
    A 2.9" on a GenV will require injectors, headers, intercooler and/or E85. No way around this, unless you want to run an unsafe set-up. Most will prefer a cam as well, to go with said mods.
    Whatever seems to "work" for you though, works for me I guess.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  5. #25 Re: 3.5-2.9 drop...OMFG!!!!
    Out West
    high EGT's
  6. #26 Re: 3.5-2.9 drop...OMFG!!!!
    Jul 2011
    B-Town, PA
    the lulz are strong with this one.
  7. #27 Re: 3.5-2.9 drop...OMFG!!!!
    Charles City, IA
    So your running rich on stock injectors with a 2.9? You must have the polished rotors mod.
    SMGPFC Two Nipple General
  8. #28 Re: 3.5-2.9 drop...OMFG!!!!
    Troy OH
    hell, if you were making that power with the 3.5, i'd have kept that. curious though, why everything else but no cam?
  9. #29 Re: 3.5-2.9 drop...OMFG!!!!
    utah
    Or at least rockers
  10. #30 Re: 3.5-2.9 drop...OMFG!!!!
    Waukesha, WI
    is a 3.2 feasable with headers genV fullsize ic and rockers?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  11. #31 Re: 3.5-2.9 drop...OMFG!!!!
    Troy OH
    i feel like that's right where you want to be
  12. #32 Re: 3.5-2.9 drop...OMFG!!!!
    utah
    its feasible. i run a 3.3 with no ic and a 3.25 at the track. takes some work and some tuning and obviously all the right little things to make it work
  13. #33 Re: 3.5-2.9 drop...OMFG!!!!
    Pennsylvania
    Quote Originally Posted by bcartman2 View Post
    timming is a rather retarded
    I was under the impression that you'd need 40lb (or whatever) injectors to go 3.2 or lower on a GenV to get enough fuel in for all that extra air. But I guess keeping the timing low will let you run. Kinda silly, though, to make a $50 part the limit on your vehicle.
  14. #34 Re: 3.5-2.9 drop...OMFG!!!!
    I live here. TLSheff's Avatar
    I have a 2.25 intercooler, headers, N*, LQ4, and the genV no cam, I know the aeroforce isnt a true measurement but it went from 230 with the correction factors to 250 with the correction factors, eventually I am going to get the car down to DynoBrian and we will see what it does on the dyno...fingers crossed. I was just amazed at how big of a change it was with the smaller pulley.
    I know I missed this thread by a couple days, so I don't mean to back up on the time tables and then call BS but last time I checked a LQ4 was a V8 small block.... or did I miss a memo about something else. Is this the key to getting high end torque in a L67 with a Gen V? Seems extensive to me to only allow 250whp...
  15. #35 Re: 3.5-2.9 drop...OMFG!!!!
    He's talking about an LQ4 MAF sensor...bruh.
  16. #36 Re: 3.5-2.9 drop...OMFG!!!!
    lq4 maf bro
  17. #37 Re: 3.5-2.9 drop...OMFG!!!!
    fuuu.... blue won
  18. #38 Re: 3.5-2.9 drop...OMFG!!!!
    fuuu.... blue won
    KK ty I was like LQ4 wut... not deep into the GenV world... yet
  19. #39 Re: 3.5-2.9 drop...OMFG!!!!
    It's just an external MAF sensor. That's it. You can use it on GenIII car's as well...I'm running a 85mm SLP screenless MAF. It does its yob.
  20. #40 Re: 3.5-2.9 drop...OMFG!!!!
    Feb 2009
    flintnasty MI
    No injectors...I am able to pull off running way rich with the tune that I have, I have no kr and the timming is a rather retarded from what I have seen on other tunes. I am sure there will be no broken internals. I know the power is low, when I was playing with the tune I got about 280hp with the 3.5....It wasnt as safe of a tune though so I dumped it.
    I have nearly maxxed out 39# injectors on a 2.9 pulley before....
  1. omfg G8 GXp
    Last Post: 11-21-2010, 03:37 AM
  2. Replies: 21
    Last Post: 09-20-2009, 09:17 PM
  3. MPG Drop
    By 2k6GT in forum General Tech Discussion
    Last Post: 08-14-2009, 11:56 PM
  4. OMFG!
    By SlowM90 in forum The Rant Forum
    Last Post: 07-30-2009, 12:02 PM
