Thread: No Headlights or Dash Lights!
Results 1 to 4 of 4
  1. #1 No Headlights or Dash Lights!
    SE Level Member transam24's Avatar
    Dec 2011
    NY
    My friends 01 GTP headlights and dash lights just suddenly do not come on. The radio and hvac display also do not light, the radio display only lights up in accessory mode. I checked both underhood and gloxe box fuses and they all tested ok. The contacts on the headlight switch looked fine and the parking/corner lights work as well as the tail lights. On a possibly related note the speaker volume goes in and out intermittently. Does this sound like and ignition switch problem? How should I further diagnose this issue?
  2. #2 Re: No Headlights or Dash Lights!
    Dec 2011
    NY
    bump
  3. #3 Re: No Headlights or Dash Lights!
    A circuit breaker feeds power to the headlights. I believe the instrument and dimming circuit are fused after the circuit breaker that feeds the heads.
    Have you checked for power coming in from the breaker?
  4. #4 Re: No Headlights or Dash Lights!
    SE Level Member 40thAnniversaryTom's Avatar
    Aug 2013
    Middletown, NY
    I am having the similar problems in my car... 02 GTP, the auto headlights intermittently work, when they don't, not even the drl's come on. when I flip the switch, neither the dash lights or tail lights come on.... the most common response I have been getting is either the light switch or the ignition. Anyone have further input?
  1. Head lights and dash lights randomly shut off
    By TheOtherNick in forum General Tech Discussion
    Last Post: 04-01-2020, 05:45 AM
  2. No headlights or dash lights when the headlights are turned on. HELP!
    By steeck1 in forum Audio, Security & Visual Electronics
    Last Post: 06-23-2012, 12:08 PM
  3. Dash Lights out and Tail Lights out on Pontiac Grand Prix 2002
    By aaronman in forum General Grand Prix Discussion
    Last Post: 05-09-2012, 08:31 AM
  4. dash lights abs and airbag lights flicker
    By reem98 in forum General Tech Discussion
    Last Post: 01-24-2012, 12:37 PM
  5. Replies: 0
    Last Post: 12-04-2011, 01:48 AM
