Thread: 98 Grand Prix Coolant and Break Problem
Results 1 to 19 of 19
  1. #1 98 Grand Prix Coolant and Break Problem
    Jan 2013
    PA
    UGHHHH I spelled brake wrong! The post got deleted on accident the first time and I hurried up and retyped it =P.
    Hi,
    Okay well I will start with the coolant problem first:
    The elbow leaked real bad and was losing a bunch of water about two weeks ago so I replaced it and the water pump. However, now I still have the light on even though there is plenty of water in it. I assume there is an air bubble in it still. It currently has the light on until the fans kick on then it goes off and when the engine is cool enough the light comes back on. Any thoughts? If so, how can I fix it?
    Second:
    The brakes shake horribly when stopping now. I thought it was the front rotors (since they were really warped) so I replaced them but there is no change. I am going to replace the back and was wondering if you guys thought it was the rear ones or not. I also was wondering how well the old pads will bed with the new rotors, they seem to be in decent shape.
    Thanks.
    UPDATE:
    - Rear rotors and pads were replaced fixing all pulsating problems. they were in really bad shape.
    - Coolant light is still on. Everything works fine. prolly just bad sensor.
    - As for tcs light. I dont care right now haha.
  2. #2 Re: 98 Grand Prix Coolant and Break Problem
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    The low coolant light is a common Gp issue.
    The sensor either needs to be replaced or cleaned, mine and many others do the same I just ignore it as I know when the car is low on coolant.
    The brake issue sounds like maybe you need to pull apart the rear brakes and re lube or antisieze the caliper slide pins and possibly the fronts if you didn't do so when you replaced the rotors.
    There is a bleeder valve to get rid of air in the system on the thermostat housing BTW.
  3. #3 Re: 98 Grand Prix Coolant and Break Problem
    do what 321 said, grease the sliders and such. but also check the front end out for bad tie rods, struts, or lower control arms/ ball joints.
    my guess is you feel the problem from the front of the car and in the steering wheel.
  4. #4 Re: 98 Grand Prix Coolant and Break Problem
    Jan 2013
    PA
    OK I do not feel it in the steering wheel at all so I guess its the back? And ill grease it and see how it goes. Also the brake pads are literally touching the rotors in the front (had to lightly force rotor between pads when installing). Is that okay?
  5. #5 Re: 98 Grand Prix Coolant and Break Problem
    GTP Level Member
    Aug 2012
    st louis park, MN
    I'm not an expert but the pads are always touching, or very close the rotor. With the slider bolts well lubed you can avoid almost all hangup or dragging.
    So as far as I'm concerned that would be fine.
  6. #6 Re: 98 Grand Prix Coolant and Break Problem
    Jan 2013
    PA
    Okay thanks. I think i am gonna just replace the rear rotors. Grease the front and rear slides, and see if i can somehow fix that coolant light. Other than that if i could figure out that stupid TCS i would be so happy. but that is for another day and i have anew car on the way. soooooo prolly wont worry about it. This car is nothing but fixing after 230k miles.
  7. #7 Re: 98 Grand Prix Coolant and Break Problem
    tcs, as in track off light? thats abs related, bad hub or wire. even a dirty plug to a hub can cause it. if you can find a bad hub or wire, have it scanned at a shop, they charge, but the scan can tell you exactly were to look and whats not communicating.
  8. #8 Re: 98 Grand Prix Coolant and Break Problem
    Jan 2013
    PA
    Yeahh. I know its not one of the hubs. i replaced all 4 within the last year and its still on. i know its around the passenger side since every time i seem to touch it i goes off for like 2 seconds when driving then stays off. I could have it scanned. and i might as my uncle is a mechanic and owes us a favor for some work i did for him. However i just really don't want to put any more money in it since i have a new one on the way. However , i may keep it as a winter beater. Id like to fix that tcs/abs light, new tires, new brake rotors in back, coolant pump light, and rear brake lines (rusted almost to the point its dangerous) and possibly a tune as it has a really rough idle atm haha.
  9. #9 Re: 98 Grand Prix Coolant and Break Problem
    Dec 2012
    Alabama
    I'd recommend changing the pads along with the rotors. Pads are fairly cheap (maybe $25 or less for a set of rears) and you'll be assured of having good contact between them and the rotors from day one. I need to do my rear brakes as well and from what I have read so far, it's a simple swap and there's no need to use a special tool to rotate the caliper or anything because of the parking brake adjuster. At least that's how it is on the '05, yours being a '98 might be different.
  10. #10 Re: 98 Grand Prix Coolant and Break Problem
    Aug 2013
    mpls, mn
    you spelled brake wrong in thread title and than spelled it wrong in your last post.
  11. #11 Re: 98 Grand Prix Coolant and Break Problem
    Jan 2013
    PA
    Hmm. >.>
  12. #12 Re: 98 Grand Prix Coolant and Break Problem
    GTP Level Member
    Aug 2012
    st louis park, MN
    Quote Originally Posted by cavell View Post
    Then this guy tried to correct your spelling.
  13. #13 Re: 98 Grand Prix Coolant and Break Problem
    Jan 2013
    PA
    Quote Originally Posted by stocker View Post
    Haha thanks for pointing that out.
    BTW I did just replace the pads and rotors and greased the slides. Everything is great now. The rotors/pads were shot. When i went to install them one pad was literally bent and it wasnt til i had almost everything together that i found out and had to tear everything back apart to get another set of the parts. it was a pain.
  14. #14 Re: 98 Grand Prix Coolant and Break Problem
    GTP Level Member
    Aug 2012
    st louis park, MN
    One of the new pads was bent? That would suck but glad it's back together and working well!
  15. #15 Re: 98 Grand Prix Coolant and Break Problem
    Jan 2013
    PA
    yup literally bent about and cracked down the center on the new one. I was mad. Guy at the store was shocked haha
  16. #16 Re: 98 Grand Prix Coolant and Break Problem
    Aug 2013
    mpls, mn
    Then you will be smarter than your average bear
  17. #17 Re: 98 Grand Prix Coolant and Break Problem
    Jan 2013
    PA
    What?
  18. #18 Re: 98 Grand Prix Coolant and Break Problem
    Aug 2013
    mpls, mn
    Ask stocker
  19. #19 Re: 98 Grand Prix Coolant and Break Problem
    GTP Level Member
    Aug 2012
    st louis park, MN
    Ask stocker
    Cavell has me confused but I wasn't going to admit it.
  1. grand Prix losing coolant while off
    By Noure in forum General Grand Prix Discussion
    Last Post: 04-08-2013, 12:25 PM
  2. 90 grand prix break line location on master???
    By copperpacecar in forum General Tech Discussion
    Last Post: 11-12-2010, 07:41 PM
  3. Coolant Smell-Grand Prix GT 2007
    By Allison in forum Introductions/Noob Questions
    Last Post: 10-29-2010, 07:23 AM
  4. '93 Grand Prix low coolant light
    By intensified in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-16-2009, 08:43 PM
