Re: leaking from somewere!
gunsn88
so how can i pass inspection with the check engine light one? i deleat it with the scanner
are you in New Jersey? if so im pretty sure there are a few guys in the state (possibly south jersey) who may be able to tune your pcm.
i'd start a new thread and call it looking for a tuner in new jersey. there should be someone who could help you out for a few bucks.
sure you could get a caned tune but you would need to send them your pcm, and wait for it to come back,(and be car less) unless you buy a used pcm and send that one off, either way it will cost more than finding a local guy to turn off the o2 sensor reporting.
its not oil no, its to liquidy to be oil. ive read that the heads leak coolant sometimes or the power steering could have a leak, this is just what ive looked up, its hard to check under all that because its so packed under the hood and under neath. im use to working on an 83 mote carlo when i got this newer car it was like other world tech for me lol
sounds good, ill post the thread about it now. thank yo ufor all the help
