Thread: battery wire???
Results 1 to 7 of 7
  1. #1 battery wire???
    Jun 2012
    florida
    My nieces 2004 grand prix has a single red wire with a connector that is attached to the positive battery cable that is just hanging there going nowhere. Her boyfriend took the battery out of the car a little while ago and I want to know if he might have disconnected that connection to something important.
    The wire is about a 12-14 gauge wire.
    Any ideas?
  2. #2 Re: battery wire???
    On the top of the fusebox there should be a stud with a nut. Battery wire should be connected there to supply the fusebox.
  3. #3 Re: battery wire???
    Yoga city
    in my gxp there is an assorment of wires that size, in my buddies base model its simple and just the power
  4. #4 Re: battery wire???
    Jun 2012
    florida
    will have to look again but should there be a connector with that that goes to the connector on the wire attached to the battery?
  5. #5 Re: battery wire???
    Usually (97-03) which I'm more common with.. the battery cable has the main lead to the starter and then a seperate to the fuseblock.
  6. #6 Re: battery wire???
    Jun 2012
    florida
    Thanks!!
  7. #7 Re: battery wire???
    Jun 2012
    florida
    Got to look at the car this weekend and I was mistaken.
    The wire isn't connected to the positive battery cable.
    There is a group of wires going the the RIGHT SIDE of the fuse box in the engine compartment and this single red wire with the connector is separated from the other wires but in the same wire loop of wires.
    Any ideas??
  1. 3 wire crank sensor vs 2 wire with 24x crank trigger
    By greenmachinegtp in forum PCM Tuning
    Last Post: 03-12-2012, 05:45 PM
  2. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  3. Trying to tun my power wire to the battery
    By Zak97GT in forum Audio, Security & Visual Electronics
    Last Post: 01-06-2011, 08:37 AM
  4. Power wire amp to battery
    By yeacashgpgt2002 in forum Audio, Security & Visual Electronics
    Last Post: 09-09-2010, 11:45 AM
  5. Battery
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-09-2009, 11:21 AM
