A few months back, the terminal on my ground cable broke off. And for a quick fix I bought one of these from O'Reilly's. And it was shyte. The terminal wouldn't close all the way around the battery post. So I cut it off and bought one of those crappy universal battery terminals. Now I'm having some electrical issues which can probably be traced back to my temporary hack job of fixing my busted ass ground cable.
So give me some info on redoing my grounds. Obviously I will need to run new wire. Since I've cut the wire twice to put on a new terminal, the cable just reaches the battery. Obviously running a new cable from the battery to the chassis is no problem. A six or eight inch pre made cable will suffice. But I need some more info on the engine ground.
So my questions to you are:
Where the crap is the engine ground? I can't see where it's bolted onto the engine. I can follow the wire to somewhere around the starter but I don't see which bolt it is.
Second, would it be feasible to run a cable from the engine ground to the chassis on the passenger side somewhere instead of bringing it back to the battery ground?
