Thread: Finally continuing customization...
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #1 Re: Finally continuing customization...
    St. Louis
    Hopefully its before you burn up the fuel pump by causing it to strain to maintain fuel pressure through a clogged filter, cause then you'll have the enjoyment of replacing not only the $6 filter, but the $$$ pump as well.
  2. #2 Re: Finally continuing customization...
    SE Level Member mousemonster1232's Avatar
    Surprise, AZ
    But to get the $6 filter changed, it's a $80 fee at Jiffy Lube. And I can't do it myself.
    I don't know how they'd get it off if I cannot.
  3. #3 Re: Finally continuing customization...
    In the past people have let shops try, fail, then force them to replace the line at their cost.
    Not condoning that method though.
  4. #4 Re: Finally continuing customization...
    St. Louis
    And for this I wouldn't even consider Jiffy Lube, unless of course you don't like you ride. Find a good independant shop and have them give it a go. They would most likely be able to deal with this better than an oil change place.
  1. Customization Help Needed.
    By Dboy23 in forum Visual/Body Modifications
    Last Post: 09-02-2008, 11:13 AM
