Thread: Torca exhaust clamps, yo.
Results 1 to 13 of 13
  1. #1 Re: Torca exhaust clamps, yo.
    GTX Level Member real diehl's Avatar
    Salina, KS
    I used a 2.5" overlapping band clamp on the driver side pipe. There's a walker part number and you can order them through o'Really's. The part number is 33226.
    Dynomax Performance 33226 - Walker Lap-Joint Band Clamps - Overview - SummitRacing.com
    I'll find a picture of the other clamp if I can. The biggest thing is you have to find a clamp that is shorter than a band clamp (width), but will still fit in between the Y on the downpipe.
    Also, the 3-bolt flange gasket is the same as most SBC header collector gaskets. You can pick them up at any parts store in the performance section. Get some good stainless bolts and RTV, along with at least one band clamp and some other clamp for the other side, and you'll love life. Mine are so quiet...I can't believe I didn't fix them earlier.
    I might see if i can snap some pictures of them for ya
    signature removed for inappropriate content.
    -bio
  2. #2 Re: Torca exhaust clamps, yo.
    SE Level Member Sl33p3rGt's Avatar
    Dec 2010
    Modesto
    I used the band clamp without the steel inserts!!!
    Actually bought some a installed them and noticed i still had a horrible leak at the Y pipe,so after a couple of month of hearing that i decided to go at it again,
    With RTV and the band clamps without the spacer/Insert/whatever u may call them,Be very friendly with the RTV...lol Slide the clamps about midway of where the header and Y pipe connect,and get to work very,tight non the less and u will have to keep going back and forth tightening both sides numerous times.
    FYI it can be done just gotta find the sweet spots =P....maybe ill take pics if i get out there for and idea
  3. #3 Re: Torca exhaust clamps, yo.
    Dec 2010
    Modesto
    FYI-The band clamps i used actually have a center insert kinda C shaped on both side,that is what i removed
    Like these for example
  1. header gasket - header clamps - kn filter
    By homerunhitter629 in forum General Tech Discussion
    Last Post: 02-21-2011, 10:00 AM
  2. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  3. What Size Torca Clamps For SSAC Headers?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 06-18-2010, 11:54 AM
  4. trans cooler with hose clamps FTL!!!!
    By gtpinsc in forum Off Topic Discussion
    Last Post: 12-24-2009, 03:10 PM
