Thread: battery replacement?
Results 1 to 8 of 8
  1. #1 battery replacement?
    SE Level Member 3100sfi's Avatar
    Jul 2011
    Canada
    I only took a cursory glance at where the battery is sitting in this (96 3100) car, but I seem to recall it being jammed under the windshield washer tank?
    Is that all I need to remove to replace the battery?
    Is 800-900 CCA in the right ballpark?
    1996 Pontiac Grand Prix SE coupe - white - stock until something breaks
  2. #2 Re: battery replacement?
    Feb 2010
    TN
    yep thats correct just change mine two months ago
  3. #3 Re: battery replacement?
    Jul 2011
    Canada
    Neat. Can I leave everything connected and just set the tank aside to swap batteries? It's probably only a handful of bolts holding the tank on.
  4. #4 Re: battery replacement?
    Feb 2010
    TN
    Quote Originally Posted by 3100sfi View Post
    mine is a 97 and it is held in with two plastic screws
  5. #5 Re: battery replacement?
    The Boss Iceman6669's Avatar
    Jun 2011
    I have a 97 and had a 96. On both of them you have to take off the washerfluid tank and the crossbrace.
  6. #6 Re: battery replacement?
    GT Level Member 99GPGTP's Avatar
    Rome GA
    cars are like a jigsaw puzzle. they go together one way.
    99gtp 3.4"on ported m90, zzp 1.0 pcm, speeddaddy headers, stock mufflers w/cat and res delete,104's,FWI,180* stat, exhaust ported heads,Dog bones flipped, 18" 350z wheels
  7. #7 Re: battery replacement?
    Quote Originally Posted by 99GPGTP View Post
    Horsesh1t.
    Its way more fun to put it together all half assed to see what happens. Or...taking it apart...
    YouTube - ‪Fastest motor swap in the world‬‏
  8. #8 Re: battery replacement?
    Topeka, KS
    Wifes 94 3100 was under the air box.
  1. Where should I get my battery
    By LowRidinCrew in forum General Tech Discussion
    Last Post: 01-25-2011, 01:05 PM
  2. Battery replacement
    By SnowDrift in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2010, 09:32 PM
  3. Battery
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-09-2009, 11:21 AM
  4. battery help!
    By DDPeppa in forum General Tech Discussion
    Last Post: 08-23-2009, 11:49 PM
  5. okay, I took the battery out of my '96 GP
    By karkev in forum General Tech Discussion
    Last Post: 06-17-2009, 09:21 PM
