Thread: Finally continuing customization...
Results 1 to 20 of 24
  1. #1 Finally continuing customization...
    SE Level Member mousemonster1232's Avatar
    Surprise, AZ
    So I have a 99 GTP, and I had started to do a bunch of stuff to it, and am now wanting to do more as I have taken a few months break doing stuff, now going to start it up again.
    According to the Safely Modding your 3800 Powered Car, it is the following:
    Item / Completed?
    New Spark Plugs / Yes
    New Spark Plug Wires / Yes
    Oil and Oil filter / No
    Fuel Filter Change / No
    New Tstat / Yes
    LIM gasket/elbow / No
    Transmission Drop Pan / No
    Brakes and Rotors / Yes
    SC Oil change / Yes
    Flip dog bones / No
    CAI / Yes
    SD headers and downpipe, ubend delete / Yes
    Reptile PCM / Yes
    Ported TB / No
    Ported SC / No
    3.4" / Yes
    And the rest on is No.
    So now my main question I suppose is...
    What do YOU suggest I do as an order of the above and the rest of things that is recommended on that post?
    It is greatly appreciated, thanks for your time reading and I can't wait to see all of your great responses.
  2. #2 Re: Finally continuing customization...
    Surprise, AZ
    No one? Not even a hint of advice?
  3. #3 Re: Finally continuing customization...
    Jul 2010
    Houston, Texas, United States
    Quote Originally Posted by mousemonster1232 View Post
    Do all the maintenece stuff first,oil change,do some flushes coolant,brake. Pan drop the trans and change filter.
    Like I said do up keep first and foremost then. I can help you with your list.
    Hope this helps a lil.
  4. #4 Re: Finally continuing customization...
    Florida
    Yeah, do all the maintenance first, last thing you need is to spend money on mods, then have a leak/problem.
    Ported TB isnt really needed until you're running a pretty decent setup, and you will need to retune for it, since it will throw off the MAF readings.
    First thing you should do is replace the fuel filter. Every single car I have owned, the filters have been clogged, and gunky as hell. Always a good idea to run a cleaner through after too, flush out anything in the lines/injectors.
  5. #5 Re: Finally continuing customization...
    Surprise, AZ
    Perhaps I can do the oil, oil filter, and fuel filter tomorrow. That should only cost about $50 correct?
    Any important tips other than be careful with the fuel filter?
  6. #6 Re: Finally continuing customization...
    St. Louis
    Don't use a Fram oil filter. Get a Wix or Delco.
  7. #7 Re: Finally continuing customization...
    Surprise, AZ
    I got all of the stuff...
    Went to go take the fuel filter out, and the freaking bolts are like rusted together from the fuel line to the bolt on the filter. Any suggestions? EVERY single thing I do to this cursed car doesn't go smoothly.
  8. #8 Re: Finally continuing customization...
    St. Louis
    IIRC, you can hold the line w/ a wrench so you don't twist if off and turn the filter itself to get it off.
  9. #9 Re: Finally continuing customization...
    Delco oil filters are good?
  10. #10 Re: Finally continuing customization...
    St. Louis
    Hell, I don't know, lol... I just figured since they were OEM I'd mention it. I personally run WIX on all my cars except the Vic, and that one get a Motorcraft.
    I guess you could go with Purolator as well. Haven't heard many bad things about them. All I know is I stay the heck away from Fram. I like my engines to remain in one piece
  11. #11 Re: Finally continuing customization...
    Surprise, AZ
    I got an ACDelco as the Autozone near me is kind of ridiculous with their stocks. But aside from that, I already used the two wrenches at once (one to keep the fuel line in place and the other to twist the filter) AND WD40 and it wasn't coming off. Should I give up?
  12. #12 Re: Finally continuing customization...
    St. Louis
    Might be time for some PB-Blaster. WD won't touch it.
  13. #13 Re: Finally continuing customization...
    Grand Island, Nebraska
    yes some kind of rust penetrator. PB works great.
  14. #14 Re: Finally continuing customization...
    Florida
    PB blaster works wonder. Let is just soak, go out and spray it, let it sit for 10m, then spray it again.... You need to let it have time to work. Another thing is to put the wrenches on, and smack one with a hammer. (not hard, just try and shock the nut, so it'll break free)
  15. #15 Re: Finally continuing customization...
    Surprise, AZ
    Yeah, I was going to use PB Blaster, but couldn't find any in the chemical cabinet. Haha. I could have sworn I had some. But I just got back from vacation, I'll try that probably in the morning! Thanks guys.
    Will keep updated.
  16. #16 Re: Finally continuing customization...
    Surprise, AZ
    I put on three coats of PB blaster in ten minute intervals, and still no luck... I tell you this car must not have had any maintenance what so ever, everything I ever try doing whether it is modification or maintenance it never goes smoothly...
  17. #17 Re: Finally continuing customization...
    Minnesota
    I was having problems with mine too. I didn't have pb blaster so I just used wd but I think I ended up using 2sets of vice grips. One was on the nut on the rail and the othe on the one on the filter and there were cranked as tight as I could possibly vice them on and that broke it loose for me. Goodluck with it
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  18. #18 Re: Finally continuing customization...
    Surprise, AZ
    I returned the fuel filter. I figured after I rubbed off a few points on the outside of the bolts it was time to throw the towel in and return the filter. I would like it replaced but I'll just end up breaking the damn thing. No way to replace it now, I'd only have like one chance left.
    ANYWAY. The oil is changed! What is next in my list of things to do to the car?!!
    Thanks.
  19. #19 Re: Finally continuing customization...
    St. Louis
    Take it to a shop and have the fuel filter changed?
  20. #20 Re: Finally continuing customization...
    Surprise, AZ
    Not gonna waste the time and money. If I start feeling something wrong with it and have a real NEED to, then I will.
  1. Customization Help Needed.
    By Dboy23 in forum Visual/Body Modifications
    Last Post: 09-02-2008, 11:13 AM
