i wasn't thinking EGR, but i had the right idea about the pcv valve. i knew it allowed gases to escape. thats whats important.
and important as part of a tune-up, which was my point.
thank you, nick
and no no, you don't have to mess with the EGR at all. i just had my terminology wrong as far as describing the PCV valve in technical terms for you.
I think I'm getting real bad gas mileage too. I drive it kind of hard, but have been laying it off the peddle for a few days and haven't seen much improvement. Any ideas? tyia
you can try cleaning you throttle body here a diy link http://www.grandprixforums.net/how-c...ody-48650.html
if you have car ramps or a jack and stands you could change your own antifreeze your self with a 5 gallon bucket, cap the bucket and take it to your towns dpw, or a repair shop and drop the old coolant off to be disposed of properly, new gallon jug of coolant is 12-14 bucks. get the green stuff.
just pull the lower radiator hose and let it drain in the pail, done, refill with water from a hose run it around for a little while, drain it again, and fill it with antifreeze and water.
if you have pets keep them away from you work area, dogs like to drink coolant, it tastes sweet to them, but it can kill them as well. hose down the work are real well after your done.
and here i am i paid for the expensive ass torx security bits.
taking the TB off to clean it is pretty easy though, Hippo. a few bolts and it's off![]()
My dad and I just replaced it, pain to get it up the driveway on no battery but it was good. Changed the pcv valve as well. Everything works great now.
