Do the rest of the windows still work from the Master (Driver's door) switch?
If they do, then check the connector at the driver's window motor. One of the pins might have backed out or the lock might not be engaged.
Also double-check the harness pin connections for the driver's window on the back of the Master switch. (Pin F, dark blue and Pin B, brown)
Good luck
