I am having the exact same problem as the OP. I've checked for leaks in my system and have tried to recharge it. The A/C clutch fuse is blown as well, and every time I put a new one in, it blows as well. Upon further investigation, I found that the A/C compressor is not engaging. This leads me to believe that the A/C clutch might be bad. There is only one harness that leads to the compressor, and none of the wires seem to be damaged, but unfortunately, I can't seem to get the harness out. Check to see if your compressor is engaging at all.
